![]() | Home > My Defender > Daisy the Doublecab |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Lurking in the mist.
![]() Click image to enlarge 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Been a bit quiet on here recently. Just spent a fortune on clutch and other Puma related gearbox/transfer box bits. Hopefully get them fitted in the next couple weeks as my gearbox does not sound very healthy
![]() ![]() Click image to enlarge 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3348 ![]() ![]() ![]() |
Nice one. LOF clutches are brilliant.
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10872 ![]() ![]() |
Hope it all goes well for you with the change over
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Cheers dude.
I have a box of bits and a lot of new tools. Just waiting for my oils and greases to arrive then I’m set for next weekend 🙈 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Hope it all goes well for you at the weekend
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 ![]() ![]() ![]() |
Hey Roy, Running double snow cowls? |
Yes double snow cowl, passenger side for the heater blower. Drivers side is now my air intake, 4inch pipe straight from the air box to wing top. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Well the day came. Operation sort clutch and adaptor shaft.
Not something I want to be doing very often but not a bad job to do if you work methodically. Also helps with the right tools and equipment. Gearbox out ![]() Click image to enlarge Comparison of new and old shaft, ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Think I caught it just in time. Old clutch is also in a sorry state. Rattling like mad. New one solid as a rock and feels nice through the clutch pedal. ![]() Click image to enlarge And back together. 16 hours all together. ![]() Click image to enlarge 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Hey Clayton,
Thanks, no I’m fortunate enough to have a membership with the club on camp, £30 for the year. Although there is a rent a ramp not far from me. At least if I ![]() ![]() All went smoothly apart from 2 bell housing bolts that go front to back so had to faff around moving the DPF! Also glad I opted for the membership as I was going to do it on th drive. Much easier with her up in the air! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Nice one on the membership
![]() So much better in out of the way of the weather and it's much better with a ramp if you got the use of one, beats doing it on the drive ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
The ramp made it so much easier. Also another set of hands was amazing whilst getting the box off.
Over 100 miles on the new bitsnow and still tight. Job jobbed ![]() Instagram - @r22oyp Roy |
Sounds like you were on a win win there Roy
![]() Good excuse to get some more miles on to run it in a bit more ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
I’m almost at 42 thousand miles now 😳 hopefully keep her going for a bit longer.
She’s got a treat coming for Xmas. Pictures to follow. ![]() Instagram - @r22oyp Roy |
