Home > My Defender > Daisy the Doublecab
Page 9 of 26 <123 ... 8910 ... 242526>
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Personally I’d ask a shop to fix the holes or even change the wing because of the holes.
Post #727101 4th Sep 2018 7:29am
Roy5695 wrote:
It is different. I’m not completely sold on the look of it yet but if it cools the area infront of the drivers footwell then I’ll be happy.
Gets so warm in the cabin in longer journeys and hoping the forced air in will help a little. If not I’ll be magic if yo a large plate that hides the holes left by the safari snorkel.
That's the engine air intake. It won't make a difference to high cabin temperatures, which are largely a result of the gearbox and exhaust under the floor. Darren
Post #727111 4th Sep 2018 8:49am
Roy5695
You sir are assuming that’s where my intake is, it it were factory spec then maybe so. But it isn’t.
Air intake is via a 4inch pipe to the wing top. So the wing side just has a hole in it. Now has more air being pushed into it when driving along. We shall see.
A new wing is on my shopping list and I’ll get to it eventually. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #727230 5th Sep 2018 5:35am
It seemed like a reasonable assumption Laughing Regardless though, I still doubt it'll help with floor temperatures, I'm afraid, as the problem is underneath. Darren
Post #727236 5th Sep 2018 7:10am
Roy5695
So far so good. Air inlet temps have stabilised. Since I put the new intake pipe in the temperatures were rising. So if nothing else it’s solved this problem upto now.
Will see how the footwell temperature goes on my journey upto the Peterborough show next week. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #727301 5th Sep 2018 11:21am
Roy5695
No more wheel on the roof. Reduce the C of G a bit! Safari equip galvanised wheel carrier fitted yesterday.
Instagram - @r22oyp
Roy
Post #729696 18th Sep 2018 7:34am
JOW240725
Looking good! Just out of interest when you swing it away does it lock open, so to speak, or just swing about?
I was admiring Daisy at the LRO Whistle
 James
Instagram @suffolk_rovers
Post #729708 18th Sep 2018 9:05am
Roy5695
Thanks James 😎
It doesn’t lock open, it has a steel cable that stops it from going too far. I’m working on an idea of a gas strut to hold it open as it’s only been on 12hours, and bashed me on the back already. Obviously with the drop down open it can’t close. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #729709 18th Sep 2018 9:12am
hank
Roy5695 wrote:
Picked up a genuine aux light switch and wired it to the LED light bars on the roof rack...
Just found your thread, a lot of nice touches on this one!
Where did you take power from for the switch?
Post #729717 18th Sep 2018 9:26am
Roy5695
Thank you.
The powers for the switch...
Back illumination is just piggy backed from an unused connector behind the dash as it’s a double cab.
Actual power is fed via a relay to the lights. The switch is just a trigger to activate the relay. Fed via a blue sea fuse box I have situated next to the battery. Thumbs Up 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #729721 18th Sep 2018 9:45am
hank
Ok thanks. I have a winch isolator solenoid to wire up using a factory switch, trying to fathom how to do it! Will research further. I have a double cab also - what unused connectors are there? Wondering whether anything is available for the switched live
edit: researched and found the answer to my own question... heated rear screen, rear washer, rear wiper. Think I will use one of these.
Post #729738 18th Sep 2018 11:45am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
http://www.defender2.net/forum/topic552.ht...p;start=15
http://www.defender2.net/forum/topic56375....ght+switch Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #729756 18th Sep 2018 1:12pm
Roy5695
yep, pretty much wired up the same as above. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #730349 21st Sep 2018 3:59pm
Roy5695
Just a couple photos before the pig shed goes back on the back 😩 **well there would have been but they won’t upload 🤔
Instagram - @r22oyp
Roy
Post #731263 25th Sep 2018 10:31pm
L110CDL
Great pic Roy Very Happy 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #732288 1st Oct 2018 7:43pm
