Home > My Defender > Grafty's Td5 90 |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
What's project blinky?? 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
29th Aug 2018 8:09am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 |
If you search 'project binky' or 'bad obsession motorsport' into YouTube it will bring up their channel. I'd highly recommend starting from episode 1. Their fabrication work is amazing 2002 90 Td5 Station Wagon
29th Aug 2018 8:13am |
Thanks just seen the 1st episode 2014 - current ..... 2003 defender td5 90 (my car)
29th Aug 2018 5:13pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10859 |
You will be hooked now Clayton.
29th Aug 2018 7:54pm |
I've just caught up to episode 18. What a coincidence about the wipers 2002 90 Td5 Station Wagon
30th Aug 2018 8:08am |
New head should be here tomorrow or Monday. Just doing the prep. Going to whip the sump off tomorrow and check the oil pump bolt and clean it out. Put it all back together then head off to the Nürburg Ring
And I'm not joking. The ferry is booked 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
30th Aug 2018 6:12pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5230 |
very brave man Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
30th Aug 2018 7:44pm |
Things progressing with putting the head back together. Doing all the prep work for bolting it all down tomorrow. Block is cleaned and prepped. Glow plugs are in and FPR fitted with new gaskets etc.
Click image to enlarge So tomorrow I'll be hopefully completing the rebuild and getting round to the other side of the workshop. The plan there is to get it onto the ramp then remove the sump to check the oil pump sprocket and clean it out. Then fresh oil, filters and coolant and it would be drivable by the end of the weekend 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
31st Aug 2018 6:17pm |
Great move forward, best of luck for you to get to the ferry on time
Good you caught up on project Binky, it was a spooky moment when i saw you doing your wiper mod Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
31st Aug 2018 7:59pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1432 |
Glad it's going to plan |
31st Aug 2018 9:12pm |
31st Aug 2018 9:15pm |
Everything is now back together. Tomorrow I'll be taking the sump off to check the oil pump sprocket bolt and then replacing all the fluids in preparation for the Nürburg Ring.
I've turned the engine over by hand many, many times and am confident that everything is clearing so tomorrow I'll be getting it running and then taking it for a drive Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
1st Sep 2018 4:22pm |
Fantastic Grafty One question, what will happen to this? since you have the classic range rover Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
1st Sep 2018 5:02pm |
The defender will become my daily again and then I can continue the restoration of the range rover - getting it to how I want it instead of getting it complete to use. So partial strip down again for final body work and cosmetic stuff 2002 90 Td5 Station Wagon
1st Sep 2018 6:32pm |
