Home > Technical > td5 rev counter |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 |
Well I would sort of hope they can impliment the pull up resistor internally themselves as it would be neater than a resistor on the outside. You never know maybe one of those switches on the back may activate a pull up anyway
25th Aug 2018 7:53am |
GerardTd5 Member Since: 03 Aug 2016 Location: almost Germany Posts: 44 |
Well done, Stefan and congratulations. How easy can it be
25th Aug 2018 8:06am |
but at lest you have proved that your one work ok. CIA need to up date fitting instruction. re pull up resistor internally switches or not |
25th Aug 2018 8:19am |
Hello all,
It is really special that the rev counter of Clive works as it should, without resistor, connecting and ready. Mine has been back at Smiths since Wednesday. I'm curious about which solution they come up with. I'll let you know as soon as I have an answer from them. GerardTd5 |
25th Aug 2018 9:25am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6613 |
Clive's works due to the ABS ECU containing the required pull up resistor.
Non ABS cars don't have any pull up on the signal line so it HAS to be in the tacho or its wiring. Glad to help sort this out, although I don't think it was totally believed about it Slightly disappointed that CAI did not at least try this themselves and it came down to me to resolve on their behalf. If they would like to send me a rev counter in exchange for my consultancy 1988 90 Td5 NAS soft top 2015 D90 XS SW |
25th Aug 2018 10:42am |
Hi Martin,
mine also has ABS, the rev counter gets a signal but does not respond to it. If I understand you correctly, a resistor will not help me. Those without ABS now know what to do to solve the problem. |
25th Aug 2018 11:33am |
Non ABS / ABS had that in Exeter in ship good pint
25th Aug 2018 4:13pm |
Click image to enlarge |
28th Aug 2018 6:30am |
1. fitting instruction
2. product testing = 3. ounce of prep = no PPP |
28th Aug 2018 7:14am |
chip butty Member Since: 12 Mar 2018 Location: manchester Posts: 8 |
Yes! I now have a working tachometer. Tested it this afternoon, used the info. from CAI and checked the readings against a scan tool.
Here is a list of the six wires. red/blue-----------------------pulse from pin 19 red-----------------------------ign. live 12v green--------------------------ign. live 12v black---------------------------earth red/white----------------------gauge illumination 12v from other gauge or side lights white/black--------------------unused Hope this helps. |
28th Aug 2018 4:19pm |
So much for the first email response saying no you definitely don't need a pull up
28th Aug 2018 4:24pm |
Quite. Glad I annoyed you into letting me sending you a resistor 1988 90 Td5 NAS soft top
2015 D90 XS SW |
28th Aug 2018 4:25pm |
I'll be counting on you for all my future electrical issues now haha
28th Aug 2018 4:32pm |
@ chip buuty do you have abs on your Landy ?
28th Aug 2018 4:47pm |
