Home > Technical > td5 rev counter |
CAI/Smiths have tachometers that work with ECU output and require
resistive load to work units have resistors in cct witch can switch in or out |
21st Aug 2018 6:42pm |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 |
You lost me here ' units have resistors in cct witch can switch in or out'
21st Aug 2018 6:59pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
I thought the TD5 ECU outputs a 50% duty cycle square wave with a peak amplitude of 5V not 12V as CAI email implies??
Steve 02' 110 TD5 Double Cab Rebuild Thread |
21st Aug 2018 7:13pm |
Does Clive have an ABS unit connected which could be performing the function of the pull-up circuit? If he has ABS and noone else has who is trying that might explain the discrepancy. CAI's test vehicle may have too.
21st Aug 2018 7:17pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6635 |
You need a resistor of a few Kilohms between the signal wire (the White/Slate down to the ECU) and the 12V supply (ignition supply NOT illumination!)
The Td5 ECU does have a programmable option for the rev counter but I've never heard of it being off. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
21st Aug 2018 7:20pm |
Rallysteve that does sound logical! We'll have to wait and see what the others say.
Martin so do you mean have everything connected and squeeze the resistor between the signal cable and the green switched live then fire up the car and see what happens? If so I'll give that a go on the weekend. 👍 |
21st Aug 2018 7:27pm |
Yes, all connected up, add the resistor into the wire side of the connector if you can. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
21st Aug 2018 7:40pm |
Click image to enlarge |
21st Aug 2018 8:12pm |
That PDF says Petrol Engines Only 1988 90 Td5 NAS soft top
2015 D90 XS SW |
21st Aug 2018 8:16pm |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
Yes, I do have ABS on my 90, I questioned the same thing myself a few posts back. I also checked the ECU configuration earlier and found the tachometer output IS enabled, as Martin says though, this is probably the case with all of them, in much the same way that some other functions are enabled by default whether they're fitted or not. Click image to enlarge I can also confirm that the ECU tacho output IS 12v and not 5v, I checked this with an oscilloscope to be certain. |
21st Aug 2018 8:31pm |
How have you guys wired these up?
Can't find instructions online specific to the Td5 version (Clive mentions a lot earlier about instructions mentioning ABS and pre/post 2002 models). Anyway, What wires are left over after connecting up as instructed? Do you have a brown/slate one left over? 1988 90 Td5 NAS soft top 2015 D90 XS SW |
21st Aug 2018 9:15pm |
I had two wires left over, a red and a red/blue.
21st Aug 2018 9:52pm |
Sorry Clive, missed that post! Steve 02' 110 TD5 Double Cab Rebuild Thread |
22nd Aug 2018 7:31am |
I no, just show that resistors in cct witch can switch in or out on models that they make |
22nd Aug 2018 8:05am |
