![]() | Home > My Defender > Grafty's Td5 90 |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10866 ![]() ![]() |
Great to see you have started on the 90 grafty
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
I'm itching to get it apart. And also crossing my fingers
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
I bet you are, hopefully your fingers crossed will work
I'm still waiting for the engine locking tools to arrive - whilst the defender is out of action I have decided to strip the dash out for another modification. I'll pop a picture up and see if you can guess what it is
![]() P.s the wiring is temporary for testing purposes ![]() ![]() Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
I don't really have a budget, I'll spend wherever needs spending to get it right. I'm already planning new timing chain and all gaskets. Also an injector overhaul whilst it's apart.
Until the head comes off I won't know for sure but I think the head might be cracked (which is fairly common on Td5s) if it is then I'll be putting an AMC head on. If not then it'll be the gasket and further investigation. My guess is (if it is the gasket) that excessive EGT may have caused the initial problem. (Probably caused by sustained load towing heavy things up big hills ![]() Also if the standard head is to remain then I'll be slightly porting it ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton Last edited by grafty99 on 13th Aug 2018 6:33pm. Edited 1 time in total |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5230 ![]() ![]() |
If you don't have a budget, then I would just go for the Head upgrade. While you have the option
![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1432 ![]() ![]() ![]() |
![]() ![]() ![]() I thought you had it just to polish ![]() ![]() Ps the blue one was still where it should have been Ta ![]() |
I might well do, however if I can get away with a gasket and mild porting then that'll suffice. Another consideration is time. I'd want to buy a plain head and have my valve train put in as I know it's in great condition. However I've got a trip planned to the Nürburg Ring in early September so want to get it done for then ![]() It has been known to tow the odd thing Jim, but is obviously well polished whilst doing so ![]() Glad the blue one is safe ![]() ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Rain sensor ? ![]() Were starting at Saunton tomorrow for a few days, so i am going to try and pop up to you for some T and biscuits ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Not a rain sensor, maybe a picture of the prototype wheel boxes and link rod will give the game away
You haven't just watched part 18 of project Binky, spooky
I've been planning it for a while, it happens that as its off the road now is the ideal time to do it. I've not yet seen the latest Project Binky episode, from what you've said I might have to watch it now
They talk about white lettering on tyres on how good it is on blue cars
Only Saturday morning ![]() ![]() |
