Home > Technical > question re: upgraded Ashcroft HD halfshafts
Page 4 of 5 <12345>
jst
Don't worry about not getting both shims on, just take play out.
For rear, don't take circlip off dm, just undo dm Bolts and take whole lot out together.
My Ashcroft dm arrived and cap bolts, just need some time now! Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #720184 29th Jul 2018 10:54am
Avelingporter
I eventually found out that PTFE stands for...
Plastic Tape For Engineers
Rolling with laughter
Post #720189 29th Jul 2018 11:10am
Oh there's was no issue with the shims, just thinner ones wouldn't fit as well like on the OE flanges.
Perfect fit with the larger shim.
I found the orientation was with the larger shim the papered side out away from vehicle and the circlip tapered side in.
Perfect fit, and this was Ashcroft HD flanges on OE splines on the front.
On the rear I'm going to replace the halfshafts and the flanges.
The drive is better already I do know, obviously the rear needs doing yet but I can tell a difference for certain.
Thumbs Up KEEP CALM AND Drill ON
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #720194 29th Jul 2018 11:33am
I shall have to stop thread hi-jacking this thread. Embarassed
But tonight I completely finished the job on the front and changed the axle oil over as well, the first time I've done it myself and all went well.
The Sealey 1LTR pump helped a lot and filled to 1.7L pretty much to filler level.
The filler plug was a bit of a pain, my breaker bar was too long and 1/2" ratchet couldn't quite get enough purchase on it as it was quite tight.
Very careful use of an old 1/2" ratchet held square on and the bottle jack on the ratchet handle eased it off and no problem from then on. Mr. Green
Filler and drain plug torqued to 60NM.
No emulsion or moisture in there, but oil was pretty dark so was definitely due a change.
Replaced with Fuchs Sintopoid 75w - 90, same brand on the rear.
Rather pleased with myself over all that, a nicer job to do compared to the Prop UJ's.
Thank you to those of you who provided advice, very helpful indeed.
Much better to ask questions and consult the WSM first than go at it hung ho and make mistakes. KEEP CALM AND Drill ON
Post #720369 29th Jul 2018 10:28pm
jst
Fitted my Ashcroft Drive Members yesterday to my 110.
Had fitted Ashcroft shafts and CVs approx 6k miles ago (along with their lockers (nice hypoid rear diff locker too) at the time i fitted some new drive members to. surprisingly amount of wear in the drive members for 6k miles., esp rear.
New Ashcroft HD ones went on a dream, no noticeable play in them. meaning no wear in their shafts or CVs, just wear in replacement drive members.
I am confident these will outlast the rest of the vehicle now. Had Ashcroft shafts and CVs with their DM running 37" for 8 years with no wear so i am sure they will cope with my 235.85s!
Have the added benefit of being sealed too with o ring so less chance of those capping seeping water in /oil out!
One more truck to do and thats the lot done then. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #721194 3rd Aug 2018 8:30am
Excellent, that's good to hear. Thumbs Up
Perhaps now shortly we can enjoy the summer instead of spannering. Laughing KEEP CALM AND Drill ON
Post #721212 3rd Aug 2018 11:15am
My rear halfshafts are now on order, shortly crack on hopefully. Thumbs Up KEEP CALM AND Drill ON
Post #721728 6th Aug 2018 1:24pm
jst
i found an hour on friday evening too so fitted the other set to the soft top. That had new DM approx 2k miles ago, there was some wear on the rear DM already (!), front was fine. (has ashcroft shafts and CVs).
Took a few pics to show steps i took and tools used.
All fitted a drea,. I used Nord Loc and no loctite to fit allen bolts. Used supplied gaskets coated in grease each side. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #721861 6th Aug 2018 9:33pm
Good job. Thumbs Up Should also ease future maintenance oo without the loctite type thread locker and far far reduce and likelyhood of any bolts snapping.
That's the key I think is to take your time and go easy on them, I found undoing them going easy enough just to crack them off was best practice without trying to force them too fast.
From there just wind them out in stages so heat doesn't build up too much and cause bolt expansion.
Loosening and re-fitting with the same pattern technique as removing wheel nuts.
Not just going bolt 1 2 3 4 5, but opposites I.e. 1 5 2 4 3 if that makes sense. KEEP CALM AND Drill ON
Post #721868 6th Aug 2018 9:54pm
jst
i always crack them by hand then wind them all out in one with windy gun Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #721906 7th Aug 2018 8:00am
Pretty much the same thing, just cracking them off is the risky part.
Some are definitely a little tighter than others.
Post #721918 7th Aug 2018 9:36am
Mine arrived today.
Superb next day delivery as well! I only ordered 12:30 yesterday lunchtime, and the packing is brilliant.
In fact it took me a while to get them out. Laughing
Probably crack on with them tomorrow at some point. KEEP CALM AND Drill ON
Post #722003 7th Aug 2018 3:46pm
Started today on the rear:
This is what I found, the splines are dry and past it but the shims appear missing?!
I can use two spare from the front but they arenโ€™t thick enough but will all the same. Iโ€™ll still carry on the job.
I would have thought there should be shims present or am I missing something? KEEP CALM AND Drill ON
Post #722218 8th Aug 2018 12:02pm
Havenโ€™t done the other side to have a look yet so far. KEEP CALM AND Drill ON
Post #722222 8th Aug 2018 12:12pm
Caterham
don't think mine have / had any shims?
so there should probably be shims there Laughing
Post #722223 8th Aug 2018 12:12pm
Page 4 of 5 <12345>
