Home > My Defender > here she is
Page 8 of 26 <123 ... 789 ... 242526>
L110CDL
Good luck for Monday Thumbs Up Clayton.
Keeper.
Post #720348 29th Jul 2018 9:02pm
razz
2001 Defender 90 Td5 PU Caledonian Blue
Cheers fella , she’s been dropped off , it’s worse than going to the dentist I believe Very Happy
Post #720415 30th Jul 2018 9:23am
razz
yesssssssss , she failed , but on two small repairs , drag link seal and side light , so they done and i can collect in the morning , yeeeeeeeeeee harrrrrrrrrrrr , oh and only 940 miles covered over the year, mainly around the pits , sounds like they replaced the seal , so i`ll bung a new draglink on her.
very pleased indeed
Post #720482 30th Jul 2018 4:18pm
razz
taken from dvla website , light and seal are now major defects , blimey
Date tested 30 July 2018
Fail
Mileage 135,903 miles
MOT test number 7011 3589 3001
Test location
View test location
Repair immediately (major defects):
Nearside Front Position lamp not working (4.2.1 (a))
Drag link end ball joint dust cover insecure so that it no longer prevents the ingress of dirt (2.1.3 (g) (ii))
Monitor and repair if necessary (advisories):
Drag link end ball joint has slight play (2.1.3 (b) (i))
Post #720484 30th Jul 2018 4:20pm
razz
She’s home , next up , new drag link and series windscreen/ flat roof
Post #720641 31st Jul 2018 10:15am
razz
The boss says I gotta leave it in one piece for a little while , so sept 9th is next pit day , so that’s it for now , catch ya all soon
Post #720739 31st Jul 2018 7:53pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
This as always is a welcome change to the mint ground up rebuilds which I love ,to know you are going to throw this in the mud makes it all the more special .Here's my TDi 200 a few years ago.
Post #720744 31st Jul 2018 8:17pm
L110CDL
^^^ nice pic legin Thumbs Up
Great she passed the mot razz with not much needed to be done Thumbs Up
Happy holiday till the 9th sep Wink Clayton.
Keeper.
Post #721140 2nd Aug 2018 8:35pm
razz
Thanks lads , it’s here to be used Thumbs Up
Post #722078 7th Aug 2018 7:35pm
razz
And we off , screen out , screen frame in , need to drill the bottom of the frame to locate it onto the defender bulkhead pins , then i’ll Work out where to cut the roof to drop down on to the flat series screen , but before all that , the bulkhead has a hole in it , now there’s a surprise Very Happy
Post #722079 7th Aug 2018 7:38pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
Have you tried to source a series pick up roof? That would fit more easily with the windscreen. Trying to reprofile and keep waterproof the defender roof will be quite a task. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #722095 7th Aug 2018 9:08pm
razz
3 hours of work done , drilled the frame to drop it onto the pins , and then go round n round n round making all the gaps look half good , need to make some plates to hold the bottom of the screen , then it’s shut the doors n fold the roof , my daughter says leave the roof and go rag top , so might even go that route , in the mean time , i’ll keep plodding along , if a series roof appears , I may grab it . As you can tell , it did look smart with the roof off . Anyways don’t look much different , but lots done
Post #722214 8th Aug 2018 11:38am
L110CDL
Certainly different Wink
Looking forward to the finished look Whistle Clayton.
Keeper.
Post #722381 8th Aug 2018 8:55pm
razz
cheers fella , its a new day and i realise i need the hardtop series roof , as its flat as i want , and not the rounded pick up version , yep i`ll have to cut it to suit the rear bulkhead glass bit , and on the way to work , i pass a ragtop version , hmmmmmm they do look good . thats the trouble with these , you can have so many versions , i did spot on the searching web , a series with a ply roof , now that would be easier , make a metal frame to hold the thing square , tiled , or thatched roof at that , yee harr
Post #722429 9th Aug 2018 6:33am
L110CDL
^^^ Laughing Clayton.
Keeper.
Post #722756 10th Aug 2018 8:17pm
