Home > Puma (Tdci) > Frequent Powerloss |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
These symptoms sound the same as I experienced. It was rectified under Service Action QO68:
Click image to enlarge HTH Brian. |
10th May 2011 7:47pm |
Witam Kijania,
Oto kopia w języku polskim RE: Silnik Brakuje Light Power On i MIL Szanowni Państwo Podczas jazdy po rozruchu na zimno silnik gdy temperatura płynu chłodzącego silnik jest <5> 35 °, a zmiana biegów jest przy prędkości silnika> 2000 obr / min, istnieje możliwość, że kontrola ciśnienia kolei dużych Zawór może kij i spowodować wysokie ciśnienie kolejowego, wycieczki diagnostycznych, odciąża kolei powoduje klienta, aby zobaczyć Awaria silnika Dioda (MIL) światło o ograniczonej wydajności i P1169 lub P0089 Diagnostic Trouble Code (DTC) przechowywanych w Powertrain moduł sterujący (PCM). Nie będzie wziąć kredyt na przełożenie jak google przyszedł do rexcue.. |
10th May 2011 7:56pm |
Kijania Member Since: 10 May 2011 Location: Polska Posts: 3 |
Thanks Lorryman100,
As far as I know and have been told, the truck is up to date on available software downloads. I have been reading the other PowerLoss thread and may look at getting a new fuel filter. When the power loss occurs, all that needs to occur to gain power again, is shutting off the truck and restarting it. I would presume that blockage in the filter would be ruled out. Sometimes the truck runs even better then before the power loss, more power and the engine seems louder but very responsive. To all a great Sunday Evening Kijania 2009 Alaska White TDCi 110 |
15th May 2011 5:08pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
See my thread about power loss.
15th May 2011 5:52pm |
jlprojects Member Since: 10 Dec 2010 Location: now in Ireland Posts: 48 |
Kijania,
If you are going past Lodz, let me know, I have a MSV2 and a few bits to help with fault finding. I'm from the UK, but my partner is Polish. If we can help in any way at all we will. John John |
15th May 2011 6:38pm |
Thanks for the kind offer John
I was able to get a fault code, P121C-00 (cylinder balance - injector leaking). Is this a common error? Any idea what to look for? thanks kijania 2009 Alaska White TDCi 110 |
21st May 2011 5:36pm |
nie jestem pewiem,mam swoj samochod 110puma od 8miesiecy,w tej chwili jest w UK i ma robiona skrzynie biegow,zamierzam go odebrac 25 czerwca i wrocic do lodzi,mam nadzieje ze wszystko jest ok,jesli chcesz sie spotkac daj znac,bedzie mi milo spotkac innego wlasciciela land rovera.
My Polish is getting better, let me know if you understand what I have said. All the best John |
21st May 2011 8:27pm |
nikojo Member Since: 06 Aug 2011 Location: Madrid Posts: 75 |
Kijania, Did you solve this problem...........I am throwing similar codes with similar symptoms?? |
24th Aug 2011 8:49pm |
