![]() | Home > Technical > td5 rev counter |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Yes slam panel needs to be out and intercooler
If you want td5 Rev counter speak to dan at Duckworth parts he was doing new genuine ones for circa 225/250 it’s worth getting the genuine one imho 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
I expect the genuine ones are just made by CAI/Smiths. They can probably supply them direct.
They need to be calibrated to the td5 output 2008 110 2.4 XS Utility (Hagrid)
The td5 rev counters are ECU controlled not altenator controlled like the older ones. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6635 ![]() ![]() ![]() |
Genuine are VDO
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1766 ![]() ![]() |
Welcome along dobbo. Would you be interested in any of the Croytec aluminium interior bits? If you are then I'm not too far away for a rendez vous at mr moo
GerardTd5 Member Since: 03 Aug 2016 Location: almost Germany Posts: 44 ![]() ![]() ![]() |
Hi Dobbo,
Geobloke on this forum has connected a vdo rev counter, see please http://www.defender2.net/forum/topic53710.html You can also try again with a group buy via Dan van Duckworths, if the price is right, I'll join. In March of this year, LandymanStefan made another attempt. Unfortunately, there was insufficient interest at the time. Cheers GerardTd5 |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 ![]() ![]() ![]() |
Ears are burning haha
CAI were part of VDO for a while. The TD5 ones were probably still made in CAI's factory. ![]() |
Hi Zsd-puma,
I think you knew it, this is whait I found on the website from smths cai https://www.smiths-instruments.co.uk/landrover. The Td5 rev counter is made by them. Thank you for the tip. Best regards GerardTd5 |
Try this one
https://www.smiths-instruments.co.uk/landrover |
I think most UK vehicle instrumentation production ended up with CAI. Smiths, VDO, Jaeger, Lucas etc. They can make stuff with a variety of brands on it.
It's a bit like Burlen Fuel Systems ended up with SU, Amal and Zenith carbs. The Market contracted, so you had lots of mergers to cut costs. |
If you get a price from smiths let us know what they're charging for one
Thanks |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
I've just put in an enquiry with Smiths for the price and availability, I'll post here if/when I get a reply
