Home > Technical > Waxoiling in Berkshire |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5012 |
Acid stripped or shot blasted etc then primed and painted with POR-15 or galvanised etc or for a more realistic approach you could use rust remover, acid treat the rust then POR-15. http://www.frost.co.uk/links list some relevant products Many similar products others might suggest. I can recommend POR-15 highly but the marine clean & rust remover I found to be next to useless
There is no point with mine, It's too far gone to waste time and money on it. The rot is from the inside out and everything on mine has been replaced at least once. As well as having a multitude of patches on it once the rear quarter chassis has been replaced it realistically has finally had it, you can't replace it a second time. Mine will go for a few more years then it will be another one of these Richards Chassis. JOB DONE! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Last edited by Zagato on 16th May 2011 7:16pm. Edited 8 times in total |
16th May 2011 6:20pm |
I've got the cheap labour in training all ready for the next job so they can keep me in rebuilt Landys once I'm old and dribbling from both ends
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
16th May 2011 6:22pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Frosts estate agents?
16th May 2011 6:51pm |
Oops will do a proper link. http://www.frost.co.uk/links I would get the POR-15 from their Mike but others can hopefully recommend better sources of rust remover/acid treatment etc. The frosts stuff was crap and expensive.
16th May 2011 7:14pm |
I emailed dinitrol to ask about the products with a couple of questions regarding what might be suitable. The guy just wrote back and said "just buy the big kit, that has everything you need". Yeah, thanks for that. Really helpful
18th May 2011 4:34pm |
Not good,
Mike, I have been speaking to a guy called Martin on www.Rejel.com which seem to be Dinitrols main outlet. He was very helpful and informative 01234 273388 |
18th May 2011 6:24pm |
The guy who emailed me is John so I may try this other chap, thank you.
Then again I'm not sure I can be bothered to do it myself. My local indy did my 90 and it's fantastic, and the likes of rustmaster seem to have a double glazing sales attitude, all sell sell sell which I LOATHE |
18th May 2011 6:32pm |
Spoke to a guy last Sunday who said he payed £700 to Rustmaster to do his vehicle. The car was cleaned and Waxoyl put directly on top before it had a chance to dry. Think I would prefer one of the many places that keep the car a few days so it can be dried after the cleaning
It's really quick and easy to do Mike, about £120 for maybe 2hours max work after cleaning. |
18th May 2011 6:38pm |
You seemed to love doing yours, you do it
18th May 2011 6:45pm |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
And whilst you're up this way Zag, why not pop across country and do mine as well? Cheers! edit: Mike, I just realised that this is entirely off-topic - better get that sorted out before we are reprimanded! Back to waxoiling in Berkshire, with sincere apologies . . . |
18th May 2011 6:50pm |
actually, serious question. light rust on chassis (not the defender). needs treatment for that and some kind of waxing. What products (dinitrol) does it require? |
18th May 2011 6:56pm |
Sounds like my ideal holiday tour, if only
18th May 2011 7:04pm |
Just buy the kit Mike! If it is light surface rust then something like Ku-rust which is an acid rust converter will stop it, one little pot stretches a long way (many similar products). Dinitrol 3125 Cavity wax will do your box sections. Dinitrol 4941 under-body wax will go over your rust treatment and sort out the whole underside. Dinitrol 445 Stone Chip is good for any areas that will get more wear and tear. As said before many other products available for all these scenarios. By the sounds of it Mike, yours gets used as intended quite regularly so you may want to do it every couple of 2-3 years. Let me re-phrase that - you may need to do it every 2-3 years..... If a soft southener can do it, you can get off your big northern bum and get under your motor - you will know it is done properly then also AND you save yourself £580 |
18th May 2011 7:15pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
To all you waxoyling experts out there............just had mine done, so for how long will my landy smell like an oil refinery?
9th Jun 2011 6:00pm |
