Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6771 |
Got my mate who makes stickers to print me out a negative version of a cruise control sticker to put on the cruise on/off switch this week.
Stuck it on in place Click image to enlarge Scratch off the paint in the gaps Click image to enlarge And after removing the sticker I don’t think it looks too bad, not perfect but passable. Click image to enlarge Got to get it all wired now Ray My build thread http://www.defender2.net/forum/topic17615.html |
27th Jun 2018 4:01pm |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 |
That looks great👍 Which cruise control kit have you fitted? 2002 110 td5
27th Jun 2018 8:10pm |
I’ve just bought the two disco switches and I’m going to wire it up myself..............................hopefully Ray
27th Jun 2018 8:15pm |
Understood...let us know how it works. Although I presume my 5th gear ratio would scupper it? 2002 110 td5
27th Jun 2018 8:18pm |
Forgot to say, I bought a speedo healer too as I’ve got the 1:22 ratio transfer box in, speedo healer should work with yours if your planning on fitting cruise. Ray
27th Jun 2018 8:22pm |
Hi Harry, I’m fitting the column switch just like yours, I’d seen your pics before so was going to copy I’ve cut the cowl already but I still need to cut the metal bit. Ray
28th Jun 2018 8:15am |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 |
Looking forward to seeing the finished result! Being honest, I copied the idea from someone else on this forum 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
28th Jun 2018 11:27am |
Finally piped up the provent so we’ll see how much oil it chucks out now
Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
28th Jun 2018 8:24pm |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1364 |
Harry, how did mount the D2 switch ? I’ve trimmed my cowl ready to fit but I have no idea how I’m going to line it up and fit it first and the get the cowl on.
28th Jun 2018 9:19pm |
I was going to fit an L shape bracket to the bottom cowl and attach the switch to that then Slot the top cowl over the switch. Ray
My build thread http://www.defender2.net/forum/topic17615.html Last edited by mk1collector on 28th Jun 2018 10:24pm. Edited 1 time in total |
28th Jun 2018 10:21pm |
Just a quick question, on the disco 2 switch, of the three wires in was the black wire the live in? Ray My build thread http://www.defender2.net/forum/topic17615.html |
28th Jun 2018 10:24pm |
Hi AJC, there's a few photos I posted in this thread if that helps. I fitted it to the bottom section of the cowl only, it seems pretty sturdy when the cowl is all bolted back together but it took a while to get it flush hence the washers under the bracket http://www.defender2.net/forum/topic58769-15.html Mk1collector - Sorry but off the top of my head I can't remember which way around and I'm currently in the wrong continent to check the Defender. Do you have a multimeter that you can check with? [/quote] 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
29th Jun 2018 6:07am |
Thanks Harry, that's great. My job for tomorrow afternoon
29th Jun 2018 6:25am |
Nice job on the cruise control Ray
29th Jun 2018 6:29am |
