Home > My Defender > 130 tipper project...
Page 5 of 6 <123456>
stanstorey
And that one picture has completely trumped my entire thread!
It looks absolutely bloody amazing Bow down
Post #713109 18th Jun 2018 10:08pm
LR90XS2011
https://farm2.staticflickr.com/1828/28013474587_ef92b7b142_b.jpg
that looks so right DEFENDER 90 TDCI XS,
Post #713115 19th Jun 2018 5:43am
LandRoverAnorak wrote:
That looks fantastic. I'm particularly liking the Disco steel wheels!
I used to have a set on my old 90. They did look good. Friend of mine had them originally and did the modification (ground out the centre, flipped and re-welded it in)
Post #713119 19th Jun 2018 6:29am
L110CDL
That is one nice 6X6 Bow down
I would agree with you Stan on the locker doors being done in limestone Thumbs Up Clayton.
Keeper.
Post #713333 19th Jun 2018 9:19pm
stanstorey
Not got around to doing the tipper storage doors yet...had enough of painting at the moment!
Fitted the passenger door as after 3 goes at painting it, it's good enough to fit!
Got the fuel filler refitted, diesel in, some injector cleaner etc in the fuel filter and it started really quickly after letting it purge. Better than it did before I took it all apart.
You learn to do things when you're working on your own - particularly when you stupidly store the diesel in a big can without a spout...
The breather pipe was just lying around when i took tank out and after a quick search on here, i found that LR had a fix to mount it on the fuel filler neck on Pumas with leaks- TD5 one on here isn't long enough to reach the neck, but plenty of room to mount it above tank with the tipper setup.
Has anyone got any experience of locating this breather so it doesn't leak etc?
Not a huge fan of stickers/badges etc, but thought a subtle reproduction plaque/badge might be suitable - Tenner off ebay
Fixed the old key!
Fitted a spare wheel mount on the back of the tipper:-
Will try and get a spare wheel cover for a 285...
Arches arrived today - hoping to get them fitted by end of the week...
Post #713531 20th Jun 2018 7:36pm
stanstorey
Bit slack on the updates...
Got most of it back together now and a lot of fiddly bits sorted.
Rear wheel arches were fun! I could not find any to suit the 285s, so had to buy double width lorry ones and reduce the width...
Fuel filter guard bent from steel sheet, painted and fitted...
Standard filthy working defender interior...washed and scrubbed!
Both front outriggers replaced...
One of the rear bump stop mounts was rotten...so i cut it off and made a new one to weld on
Two new track rod ends and the other two ends had new boots for MOT..
New steering damper as I had one in stock and I presume the one on there is ancient!
Tidied up centre console that was hanging off.
removed the LR radio that no one knew the code for...fitted a basic CD unit I had kicking about
New aerial fitted...and low and behold both speakers work - even better when i removed all the woodchip from them!
Quite pleased with how the old girl is looking with arches on and a nice blackened chassis and some shiny new tailgate pins!
I can no longer see any rusty bits anywhere!
Left to do...
-Fit windscreen which is here and I have been putting it off
-change all the box and axle fluids
-fit rear bump stops as I keep forgetting
-flashband the passenger door
-fit some grab handles to doors to pull them shut
-fit the front mud flap kit that arrived today and maybe look at making some outrigger mud guard thingys from some plastic sheet
-MOT at local(ish) landy place and get them to see why it is rather flat to drive.
-get a price from them for clutch and any faults which are causing the lack of power
-modify the hilux surf rock sliders to fit
-drive it for a bit then most likely advertise it as the more i look at it, the more i realise I cannot get wife, toddler and two dogs in it!
I have also managed to sell my green and cream 110 - but had to take a PX Rolling Eyes
So now have this to tidy up and move on:-
https://flic.kr/s/aHsmiNFnuf
Post #717393 12th Jul 2018 8:39pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
Very very nice ,really like the choice of wheels so easy to go with alloys ,length of the bed is just right and the colour just set the complete truck off.
Post #717402 12th Jul 2018 8:59pm
L110CDL
^^^ nice p/x Thumbs Up
The old girl is looking proper Bow down Clayton.
Keeper.
Post #717404 12th Jul 2018 9:02pm
bankz5152
Awesome thread. Lovely build Very Happy Instagram @defender_ventures
Empire Tuning - Agent
Post #717413 12th Jul 2018 9:21pm
That's fantastic. Looks like it belongs in the outback. Darren
Post #717427 12th Jul 2018 10:20pm
stanstorey
Thank you for the kind words!
Bit slow on the recent updates...but it's now MOT'd - not sorted the lack of power - but it usable and legal!
So since last update i've fitted windscreen, adapted rock sliders, tidied up more interior, changed all the fluids underneath, fitted rear bump stops and MOT'd
Rock sliders:-
Hacked off hilux mounts:-
Offered them up:-
reused as much of old brackets as possible to make new brackets and extend them to fit:-
Mounts on bulkhead bolts at front as most sliders do...
Extended them a few inches and added some nice chunky box to locate them on the spare chassis outrigger
I also welded an extra bit of 6mm plate to the outer 100mm of the rectangular box section mounting - I thought this might make a good jacking point and a bit of extra steel wouldn't go amiss?
Primed:-
Painted and fitted:-
M12 bolts x 3 and large plate washers.
Fresh fluids:-
Just back from MOT Very Happy
And before any keen of sight spot it....I didn't do any welding with the full drum of acetone propping up the slider when on the ramp Laughing
Post #720752 31st Jul 2018 8:48pm
Cool Cool I'm very jealous of your ability to glue steel together. Darren
Post #720755 31st Jul 2018 9:02pm
legin
Why do early doors look so much better ? Great looking truck .
Post #721495 4th Aug 2018 9:14pm
Fantastic job, I agree about painting the lockers.
Post #721515 5th Aug 2018 6:50am
Pilgrimmick
https://flic.kr/p/JSyH38
Is that the mythical centre steer prototype 130? Rolling with laughter 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #721527 5th Aug 2018 8:59am
