Home > My Defender > 130 tipper project...
Page 2 of 6 <123456>
stanstorey
Refitted the treated and painted tank cradle - just caught it before it rotted beyond repair. Having priced up a new one and a matching tank strap I am rather relieved! Shocked
Obligatory trial fit of larger wheels Laughing
285 75 16 on reverse centred disco steels
Post #706858 13th May 2018 6:51am
stanstorey
New rear light brackets in the making from an upcycled old Aga heat tray thingy - grease removed...
already has a strengthening fold at each end and if you cut it in half it will make two brackets...
more pictures to follow - hopefully some more interesting updates!
Post #706861 13th May 2018 6:57am
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
I have always liked Hi Caps and have owned a couple over the years including this early one ,not as nice as yours which I really think is one of the best I've seen.
Looking forward to watching you turn this one around.
Post #706862 13th May 2018 7:05am
stanstorey
That's exactly how my 110 would have looked - always wondered what it looked like when it was new! Thumbs Up
Post #706863 13th May 2018 7:10am
ARC99
Like the look of your 110, saw something similar in either Plymouth or Buckfast last summer .
I have never been a great fan of wire wheels on angle grinders after one exploded on me and I had to spend sometime in A&E having bits of wire removed from a delicate area Embarassed , they had embedded themselves quite deep after traveling through a pair of overalls and trousers. I now use 3M surface prep disc's. Don't make old people mad.
Richard
Post #706865 13th May 2018 7:20am
stanstorey
The perils of metalworking!
I do not even pick one up switched off without a proper set of goggles on...they are evil but effective things!
Post #706867 13th May 2018 7:37am
L110CDL
Great work you have done so far, loving every moment of this thread Thumbs Up Clayton.
Keeper.
Post #707190 14th May 2018 8:32pm
stanstorey
Few quick update pics...
Had to cut off the shock mounts as they were completely seized to the top shock bush.
So new mounts and bolt kit for each side:-
Light mounts (now sprayed, but were drying):-
Going to run 3 x NAS lights and locate the reflector separately.
Plenty of Rolling Eyes moments sorting out rear axle!
Bruised thread on a stub axle - nut was particularly stubborn coming off, so thread needed cleaning up Rolling Eyes
Voila
Both Drive flanges were b*&gered Rolling Eyes
Half shafts both good, so i guess they replaced them and not the flanges...and used any old bolts they had!
The other sides stud had obviously snapped off inside the hub assembly, so someone had welded a bit studding onto the hub... which then sheared off Rolling Eyes
Hub:- Rolling Eyes
Drilled with a 6mm bit...then some easy out thing and it came out with ease - a rare thing! Whistle
Put it back together.....bearings a bit worn, so off it comes again Rolling Eyes
New discs, pads fitted and just awaiting new drive flanges and bolts to arrive.
I think they warranted changing...pads were nearly new - i don't get the logic!
Oh and this is always an easy and satisfying job Laughing
And finally - I treated myself to a brake pipe kit - been meaning to learn to make my own for ages and this 130 needs a new front to back pipe for the MOT
Post #707977 18th May 2018 8:13pm
dorsetsmith
keep up good work Thumbs Up
Post #707980 18th May 2018 8:20pm
stanstorey
Thanks - I am strangely enjoying this one, maybe it's not having the pressure of getting it back on the road ASAP!
It is of course costing more than i pretended it would to start with Rolling with laughter
Post #707982 18th May 2018 8:36pm
NickMc
I had a tipper and put the air helper springs in it was a great idea. Pump them up when you have a heavy load and not a back breaking teeth chatterer when empty.
Post #707992 18th May 2018 10:07pm
Re: 130 tipper project...
stanstorey wrote:
This is the 110 i have (and am selling!) which i want to base the theme on
I've drooled over that on eBay for many weeks. Mrs G is probably sick of me showing it her. I LOVE that thing Bow down
Post #708005 19th May 2018 5:14am
stanstorey
It's still for sale! Also take a fair chunk off price if that helps Wink
Post #708024 19th May 2018 7:28am
stanstorey
Few bits done this week...
Stripped dented front wing off and broken it down ready for new side and front panel-
6mm 70mm wide bit of flat welded about 650mm along the bottom of the chassis rail for a bit of added strength as this section had a few small holes and was a bit thin in places.
Will tidy up any welds when access is easier on the ramp!
Rear lights fitted:-
Will put reflectors on cross member or tipper frame above.
An unexpected cost, but very necessary!
Need to make up a guard as that is missing.
Tank in with salvaged tank strap and some stainless bolts, ARB refitted and chassis stone chipped with that Gravelex stuff
Rear end back together with lights, tow bar assembly etc.
Just some rewiring to do due to awful bodged light connectors with silicone and tape!
Double washered the light mounts so it leaves a gap for hosing out any mud,rather than creating a rust trap...in theory!
Yes, I will cut the tekscrews down to tidy it up
Post #709326 26th May 2018 5:16pm
stanstorey
Practising spraying on the tipper frame and tow bar etc before i try some panels!
Winch bumper was going to be repaired....but s*d that! It's going for scrap.
Never had to beat off a bumper with a lump hammer and pry bar before...
On the list and parts ready!
Post #709328 26th May 2018 5:24pm
