Home > Puma (Tdci) > Rear diff oil leak |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
I've got a small leakage from the back diff.
I guess it's just the seal. To repair this do i only need the seal (FTC5258) or other parts? And if i'am replacing the seal is it wise to change some other components as well (like the bearing etc). a defender from 1984 pretending to be a puma with a touch of Range Rover |
23rd May 2018 7:21am |
Click image to enlarge As MK stated You need to check the flange for wear, if its bad you will fell grove not flange your working with but wear in the same place i.e. where seal runs |
23rd May 2018 12:10pm |
Thnx both.
Can I check for wear from the outside? Ie play in the flange? Or can this be done solely from the inside? And are you sure that it is a 100nm torque setting? I can't find the correct setting for this in the workshop manual a defender from 1984 pretending to be a puma with a touch of Range Rover |
23rd May 2018 12:15pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2436 |
No. You need to remove the flange. 100Nm for 110" Puma. Puma 110" SW
23rd May 2018 12:41pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20549 |
Defintely 100nm for the front and rear diff flange bolt for both 110 and Puma.
My guess is you just need a new seal, at least for now. If the flange is worn it'll buy you a bit of time to sort funds out if you did need to replace it. As the seal is cheap as chips, the Genuine flanges are about £260 + Mine has leaked multiple times now, if I was you I would check your prop UJ's too as I have found lately that failing or failed Prop UJ's will cause the diff oil leak as well. You may as well, as you'll proactively have the prop off anyway and you can't always easily tell if they are kaput whilst in situ. The UJ on mine failed, on the prop yokes nearest the rear diff nose, and cause the pinion seal to leak too. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
23rd May 2018 12:58pm |
Thnx Steve,
But a little voice in my head is wondering if we are talking about the same thing. And that is because english is not my native thing of course When I look for the flange part nr TXW500010 comes up. And a original LR one is about 90 pound not 260. a defender from 1984 pretending to be a puma with a touch of Range Rover |
23rd May 2018 1:14pm |
23rd May 2018 1:20pm |
interesting to get two flange kit see the diffract |
23rd May 2018 1:40pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17517 |
Be careful with the flanges. I have had two aftermarket (but not Britpart which I would expect to be defective) flanges which have been machined out-of-round and with which there was not a snowball's chance in hell of a good seal. I now check the diameter in several places with a micrometer before fitting a new flange.
I have not had this problem with genuine flanges, only aftermarket. |
23rd May 2018 1:45pm |
No I'll buy original.
But steve said that they will cost 260 + but when I look they are about 90-95. So I was wondering are we talking about the same part. a defender from 1984 pretending to be a puma with a touch of Range Rover |
23rd May 2018 1:52pm |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 |
anyone used an Speedi Sleeve?
Video also explains the wear... |
23rd May 2018 1:53pm |
I was wondering are we talking about the same part (yes we are ) i had look flange kit LRJ up to 06 as Steve saying pox cost £260 post 07 too 09 pox cost £78 kit has new part number and mud shield can be used on ever flange the only thing left is the flange and bolt, washer |
23rd May 2018 2:26pm |
Oh it is just the LR pricing method.
Set a price based on cost. Then take two dice. One dice with three * and three with / and a regular dice. Price * or / number of eyes = new price and of course part number Guess I got lucky this time. a / and a 3 a defender from 1984 pretending to be a puma with a touch of Range Rover |
23rd May 2018 2:37pm |
LRJ Genuine flanges, TXW500010 kit with flange and mud shield only no bolt or seal £ 78
LRJ Genuine flanges, Stc 4858 kit with flange and mud shield ,bolt, seal, nut, split pin £ 260 |
23rd May 2018 5:07pm |
