Home > Puma (Tdci) > Rear diff oil leak
Page 3 of 3 <123
LR90XS2011
well fitted the new seal today, only problem I had was the flange didnt want to come off the pinion and as I had no puller, so I had to make one out of some strip steel and a few bolts which extended the job somewhat.
If I was to do this again and had a puller I would say 1.5 hrs max, and all done lying under the car. Have driven it about 10 miles and all looks good so far.
Tools you need
standard sockets
100nm Torque wrench
Prop shaft bolt spanners (or struggle a bit with normal ones)
and a small flange puller.
screw driver (to pull the old seal out)
and I didnt have to drain any oil out the diff and lost none in the process, checked and it was still full so my leak must have looked worse than it was DEFENDER 90 TDCI XS,
Post #762796 10th Mar 2019 3:41pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
I’ve got a leak on my Ashcroft rear diff ☹️ Not 12 month old yet Shocked
Post #762815 10th Mar 2019 5:45pm
LR90XS2011
done about 100 miles leak not reappeared so happy again for now DEFENDER 90 TDCI XS,
Post #763996 17th Mar 2019 2:59pm
Page 3 of 3 <123
