Home > Td5 > Replacing original LR Radio
Galtymore
Ireland 2005 Defender 90 Td5 HT Caledonian Blue
Have recently bought a defender 90 hardtop
The original Radio was still in place but not working
After stripping out the dash etc, and got to the back of the radio but could not find a way to release the connector at the back..is there a trick I'm missing?
Also, what adapter do i need to get new radio to fit the defender connectors?
Thanks
Post #701051 15th Apr 2018 5:30pm
If it's anything like the Puma it'll have two side locking tabs, if you can get to the rear and push them in they should release.
Or if it's got a 4 hole key pattern on the front buy ISO DIN. keys, they are under a Β£5.
You can make your own, but often not strong enough and not even worth the hassle. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #701057 15th Apr 2018 5:55pm
grafty99
I would imagine it's the BMW connector which has a strange slide and lock type connector.
The outer piece slides to one side which unlocks and partially removes the plug Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #701204 16th Apr 2018 7:34am
AMBxx
I remember having similar problems with mine nearly 10 years ago. I ended up removing the whole section around the radio and manually operating the release mechanism.
I'm sure it was obvious, but only once I'd ripped the whole thing apart.
Post #701205 16th Apr 2018 7:36am
grafty99
Mud stuff sell the adaptor you need but it's basically an older BMW radio connector. I'm sure Halfords would have it Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #701206 16th Apr 2018 7:42am
Galtymore
Thanks a mill for the feedback- much appreciated!
Post #701219 16th Apr 2018 9:24am
