![]() | Home > Td5 > Replacing original LR Radio |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20715 ![]() ![]() |
If it's anything like the Puma it'll have two side locking tabs, if you can get to the rear and push them in they should release.
Or if it's got a 4 hole key pattern on the front buy ISO DIN. keys, they are under a £5. You can make your own, but often not strong enough and not even worth the hassle. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4800 ![]() ![]() ![]() |
I would imagine it's the BMW connector which has a strange slide and lock type connector.
The outer piece slides to one side which unlocks and partially removes the plug ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1051 ![]() ![]() ![]() |
I remember having similar problems with mine nearly 10 years ago. I ended up removing the whole section around the radio and manually operating the release mechanism.
I'm sure it was obvious, but only once I'd ripped the whole thing apart. |
Mud stuff sell the adaptor you need but it's basically an older BMW radio connector. I'm sure Halfords would have it
Galtymore Member Since: 15 Apr 2018 Location: Tipperary Posts: 2 ![]() ![]() ![]() |
Thanks a mill for the feedback- much appreciated!
