Home > Tdi > 300tdi - turn key and eventually starting
charcoal
United Kingdom 2005 Defender 110 Td5 HT Bonatti Grey
This mourning when I went to the Land Rover I started it as usual but when the glow plugs finished I turned the key to position 3 and nothing again, like a problem I had a few months ago. I decided to hold the key and after about fifteen seconds it cranked and started like normal. Any ideas as to why this is? Stuck solenoid on the starter? Started perfectly fine up until this point and started again fine this afternoon from cold. 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold
1995 Land Rover Defender 110 V8 Station Wagon ~ Sold Sad
1985 Land Rover 110 ex mod project Tithonus ~ Sold Sad
Post #692614 11th Mar 2018 5:01pm
Does yours have the factory fitted alarm with the two button key fob? If so, it could be failure of what is known as the 'spider unit'. This is part of the immobiliser system. They're well known for developing dry joints on the circuit board to the extent that Land Rover eventually produced a little by-pass loom that plugs in in place of the unit itself.
I had exactly the same on a 300tdi Discovery some years ago where it would, intermittently, crank but not start. Darren
Post #692616 11th Mar 2018 5:05pm
charcoal
Thanks for the suggestion, it does indeed have that type of alarm and I still haven't removed it for some reason. Will look into that Thumbs Up 1999 Land Rover Defender 110 td5 station wagon
Post #692741 12th Mar 2018 3:20am
EuropeDefender
Italy 1998 Defender 90 300 Tdi SW Coniston Green
I had similar problems on my 1998 300Tdi.
I removed every alarm related part and put a "bypass" (you can find it on Ebay) in the black box under left seat.
No more problems!!!
You can try first with bypass. Si Vis Pacem Para Bellum
Post #698112 2nd Apr 2018 9:28pm
charcoal
Thanks, will check it out, hasn't been to much of a problem lately but a permanent fix is always better than a temporary one Thumbs Up 1999 Land Rover Defender 110 td5 station wagon
Post #698130 2nd Apr 2018 11:15pm
charcoal
Are you on about the bypass part AMR 5956 by the way? 1999 Land Rover Defender 110 td5 station wagon
Post #698132 2nd Apr 2018 11:20pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
The most common issue with the “spider” was dry joints on the solder,
I had similar issues with my 300 tdi disco. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #698141 3rd Apr 2018 6:30am
EuropeDefender
I mean this one:
https://www.ebay.it/itm/TRIUMPH-DAYTONA-67...SwQaJXR2qK
and it seems its code is AMR5956 by the way Si Vis Pacem Para Bellum
Post #698145 3rd Apr 2018 7:26am
EuropeDefender
Sorry, that's not the right one. Si Vis Pacem Para Bellum
Post #698204 3rd Apr 2018 12:52pm
charcoal
No worries I found somewhere that sells one marketed as for a Land Rover, will get one and check it out. 1999 Land Rover Defender 110 td5 station wagon
Post #698218 3rd Apr 2018 2:01pm
charcoal
Well its been about a week since I fitted the bypass and everything seems normal again. No delayed starts or complete failure-to-starts. There was a parking space in the local tesco that was notorious as five times I parked in the exact place it wouldn't start at all, but elsewhere in the car park it was fine Laughing . Parked there a few times now and haven't had any issues so hopefully that is problem solved Thumbs Up
Will update the thread again if it comes back 1999 Land Rover Defender 110 td5 station wagon
Post #700699 14th Apr 2018 1:48am
L110CDL
Nice one charcoal Thumbs Up Clayton.
Keeper.
Post #701372 16th Apr 2018 9:19pm
familymad
Is it this. We are having similar issues with our 90?
Thanks
 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #972437 26th Nov 2022 12:00pm
donmacn
Yep, that’s it. Inside there there’s a multiplug thing, and the bypass plug just slots in. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #972439 26th Nov 2022 12:13pm
familymad
That looks riveted in and not an easy removal! 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #972443 26th Nov 2022 1:49pm
