Home > In Car Electronics > The definitive Defender ICE thread
Page 62 of 70 <123 ... 616263 ... 686970>
CarMan
Thanks for the offer and encouragement. Actually, I was planning to put it behind the cubby, but where to locate the other components?
Post #697894 2nd Apr 2018 11:50am
There aren’t extra components that I’m aware of except for wiring. IIRC there is a plug specific loom for plug and play. It’s a active sub, so the amp and sub are combined in the same unit. A sub and amp separate are a passive set up. $W33T $0U7H3RN $UG4R
Post #697899 2nd Apr 2018 12:01pm
CarMan
Sorry for the slow reply Rolling Eyes
Maybe I was just confused by the pic on the Bay listing Question
Post #699362 8th Apr 2018 12:01pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
You can also design a custom cubbybox Whistle
No need to put it behind like LR does Rolling Eyes a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #699375 8th Apr 2018 12:59pm
CarMan
So, this SWE-1200 is just bolt behind the cubby, then plug and play Question
Post #699636 9th Apr 2018 5:53pm
mk1collector
The Landrover version is plug and play if specked from factory but the picture you put up is the standard alpine version which looks like it has a seperate amp and optional controllers, so you will need power, Earth and ignition live to power it and rca leads from the back of the stereo to send signal to it. All reasonably easy to do but not totally plug and play. Ray
My build thread
Post #699641 9th Apr 2018 6:00pm
CarMan
Thanks for the reply, so now I know that I need the LR version, which I am sure I will struggle to find at a reasonable cost Whistle
Post #699647 9th Apr 2018 6:19pm
@CarMan, it's a good job I didn't come down in the 300, the ICE in that would have had you spending Thumbs Up
Post #699680 9th Apr 2018 7:48pm
DSC-off
Fitting the Landrover version of the Alpine sub is not straightforward. There is a wiring loom needed that doesn't come with the sub and is not generally available from a dealer.
It will be less bother to fit the aftermarket Alpine sub, amp and controller, mounting the extra bits in the cubby box.
Post #699688 9th Apr 2018 8:01pm
If you want the Genuine type I'm sure it'll come at an extortionate price tag.
Might be a very long shot, but might be worth asking a breaker if there is any in at all. $W33T $0U7H3RN $UG4R
Post #699691 9th Apr 2018 8:12pm
CarMan
Thanks Greeni for sparing me that at least Wink
Thanks DSC-off for the heads-up Rolling Eyes
Think I can feel a chat with my local ICE specialists coming on, but they aren't shy Big Cry
Post #699700 9th Apr 2018 8:16pm
Out of interest, what RCA cables are others running?
Not much discussed regarding these and I'd be interested to know what others are running. Thumbs Up $W33T $0U7H3RN $UG4R
Post #701737 18th Apr 2018 5:51pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Guys
Ive got a genuine type sub siting in my shed taken out of our 2012 xs110 ... - any one have an idea of the price of this unit
as have no idea of their worth ...no wiring loom though
(I’ve also got the alpine head unit to go with it )
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #701744 18th Apr 2018 6:54pm
Just a few teaser shots here at the moment. . . .
I'm 80% there with my intended system, but delayed a bit again due to servicing due and a few other repairs to pay for.
In the pics you're looking at 0ga primary power feeds, plus 4ga primary power feeds. (Distribution set up, split feeds.)
12ga speaker wire.
A little oversized, but I like it that's way.
The cable is the best TOFC I've ever had, and very very flixible.
0ga is rated up to 350A, so way way way more than I need but is better to reduce voltage losses.
Bigger is better, in this case. Whistle Twisted Evil
You cannot buy this quality of cable here in the UK. 🇬🇧 You can get OFC
(Oxygen Free Copper, but, not Tinned Oxygen Free Copper.) at least from any brands I would like specific to audio.
And I do indeed want quality brands..
Autoleads Proflex OFC, was good but has been discontinued in production.
Definitely always avoid CCA or KCA. (Copper Clad Aluminium.)
It's commonly known for causing your system significant voltage drop.
This new cable I have got is TOFC by Knu Konceptz. 🇺🇸 I'm really pleased with it.
It is however, very expensive as expected with high copper content and prices.
More to come in due course.. Twisted Evil $W33T $0U7H3RN $UG4R
Post #704835 2nd May 2018 6:20pm
ngins
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Corris Grey
Sub Wiring to Battery Box
Hi All,
Sorry - I have gone right through this thread (although not all in one go so I may have missed something) so just checking on the consensus. I like the idea of a Focal iBus Sub under the cubby (in a box - MUD or Far Corners maybe?) as I get the extra front amp as well. I have seen a few posts stating not to put the sub under anything if you can help it - is that the consensus or is it ok?
Either way, does anyone have any photos of how they have wired (routed) sub power to the battery (back to the head unit I am fine with). Is it easier to put a hole under the cubby and then come back up though the battery box, or route inside? I am always reluctant to put any more holes in things if I can help it. Will be fitting to a 2013 Puma 110....
thanks in advance and sorry if this is already posted somewhere - I am going ICE blind......Smile
Post #705031 3rd May 2018 4:57pm
