Home > In Car Electronics > The definitive Defender ICE thread
Page 61 of 70 <123 ... 606162 ... 686970>
stephan123
Big Cry
In that case I will play it safe and go to a local audio fitting centre. Thanks for the heads up!
Post #695702 23rd Mar 2018 3:39pm
V8Simon
United Kingdom 1985 Defender 90 V8 Petrol SW Auto Arles Blue
Puma rear speaker connections?
Hi, hoping for some help. Having put a puma bulkhead in my 90 with the new dash I'm in the process of fitting a stereo. I have the head unit working through the standard dash speakers but i want to put some in the rear also. The standard stereo connections apparently include the capability for rear speakers but where do i connect the wires from the rear speakers to?
Post #697055 29th Mar 2018 7:50pm
Do you mean you want an additional rear pair or are you currently running the front two only and nothing at the rear?
I presume you are using the factory HU (stereo) ?
Do you have a standard harmonised DIN ISO connector block at the rear of the HU LR loom. $W33T $0U7H3RN $UG4R
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #697064 29th Mar 2018 8:28pm
V8Simon
Ive fitted a kenwood HU as there was nothing there before using the two standard plugs in the dash to make it work. i am running the front two speakers only and would like to run an additional 2 in the rear.
the HU has a load of connections invthe back but is working fine just using the 2 ISO (?) connectors that are part of the dash wiring
Post #697080 29th Mar 2018 9:18pm
I see what you mean.
Are connections present and wires connected for the rear two speaker channels? I.e. are they connected at the plug?
Also.
Are the wires present to the rear behind the speakers ready to be connected or currently are connected? $W33T $0U7H3RN $UG4R
Post #697172 30th Mar 2018 11:22am
V8Simon
Thanks for the help Steve,
The plug does have the speaker connections & wires for rear speakers, but they disappear in to the loom and I've no idea where they come out. I'm presuming there's a separate plug or something for the more advanced systems (not mine) that have OE amp & whatever???
Photos of mine....
Post #697270 30th Mar 2018 6:26pm
Difficult to see but it looks as if the connections are present at the HU end.
Have you looked for the wires behind the speaker panels at the rear? $W33T $0U7H3RN $UG4R
Post #697280 30th Mar 2018 6:54pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Can anyone recommend a single DIN unit that does the following:
DAB (never managed to get FM working properly)
Flip up screen with reversing camera input
USB connection for MP3 files on memory stick
Nice to have would be a bluetooth phone ability but only if it has a plug in remote microphone.
Oh and it needs to be a sensible price (read very sensible price).
Thanks in advance for any suggestions. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #697285 30th Mar 2018 7:02pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Whatโ€™s a really sensible price? a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #697296 30th Mar 2018 7:24pm
I would look at Clarion or Pioneerโ€™s offerings.
However, you are looking at ยฃ300 to ยฃ500. 2 DIN or 1 DIN flip up arenโ€™t cheap unless extremely basic unfortunately. $W33T $0U7H3RN $UG4R
Post #697299 30th Mar 2018 7:26pm
V8Simon
As mine is a 1985 vintage, I don't have anything in the rear, i'm presuming there is a connection somewhere in the dash for an extension to the loom for the rear speakers in 110 & station wagon versions and I was hoping someone would know what I'm looking for.
Post #697421 31st Mar 2018 11:27am
It has been known for the connections to be present hidden away at the front against the bulkhead. $W33T $0U7H3RN $UG4R
Post #697478 31st Mar 2018 5:12pm
V8Simon
Thanks, I'll keep looking... Confused
Post #697492 31st Mar 2018 6:04pm
CarMan
Knowing nothing at all about ICE I think I'd like to plan a modest upgrade.
Head unit is an Alpine CDE-133BT with OEM speakers. Truck is a 2016 XS hard top.
I quite fancy the Alpine subwoofer(?) behind the cubby and fancied the Alpine-SWE-1200 but I'm now thinking it's not a quick and easy total newby job?
Bang for buck, what is the best thing I should do? Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #697679 1st Apr 2018 4:55pm
Tdi4
If you want to put it behind the cubbybox itโ€™s quiet easy. If you want it in the cubbybox itโ€™s a different story Rolling with laughter
In other words. I have the same unit. Itโ€™s great!!
Iโ€™ve designed a custom cubbybox which houses the alpine unit (and an extra drawer). If you want i can take a Photo. But it is a great unit which gives Some umpfff to the music. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #697717 1st Apr 2018 6:05pm
