Home > My Defender > Grafty's Td5 90 |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 |
I think I may have opened a can or worms
Anyway.. will we get to see some pics of the webasto install ? 1993 200Tdi Defender 90 |
19th Mar 2018 10:47pm |
Did you rivet you dirt defenders on? or attach them with something else... ? 1993 200Tdi Defender 90
19th Mar 2018 11:02pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 |
Webasto pics coming soon
Dirt defenders were riveted on yes. I drilled the holes and then painted them to prevent corrosion. Then when I installed them I applied grease to the rivets 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
20th Mar 2018 7:27am |
Well today really has not been a very good day at all.
Ever since I changed my coolant in January I have had great difficulty bleeding all of the air out of the system. And for the first time ever this happened......... Click image to enlarge Anyway today I tested for combustion gas in the coolant and unfortunately it would seem that there is. So there we have it. After 127,000 miles I have had my first major fault with my defender Will now park it up and focus on getting the range rover on the road. Once I have transport then I'll take the head off the defender and see what happens. Looks like Mondays Cornwall meet will have to be in a different landrover product Did I mention? 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
30th Mar 2018 5:16pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Run hose full on in header bottle with bleed open
Once de aired drain a bit out of header and add coolant 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
30th Mar 2018 6:00pm |
Yeah I've done all that, including having it vacuum bled.
Unfortunately exhaust gas is getting in and creating air locks, it's only now that I've had a chemical test kit on it and confirmed that there is a problem. I change the coolant every 2 years regardless and have never had a problem bleeding the system before. Thats why I had a hunch there was a problem looming. I'm guessing that the gas leak had just started when I changed the coolant and has progressively gotten worse over the last few weeks whilst I've been bleeding the system a lot! 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
30th Mar 2018 6:08pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5230 |
head gasket on its way? Be worth seeing if you can get an up rated one plus you can see if you can get some head work done.
check the dipstick for mayno Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
30th Mar 2018 6:41pm |
No other symptoms. All the fluids are staying in their correct places. Just combustion gas leaking into the coolant system. It's either a failed gasket or cracked head (Or both)
If it's a cracked head then I'll be getting a ported and flowed one from Turner Engineering 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
30th Mar 2018 7:00pm |
Have you check fuel cooler and if you still have egr cooler?
Did you get payment for the vents bud? 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
30th Mar 2018 7:25pm |
Fuel cooler and EGR cooler both ok. Money received thank you - will send out on Tuesday 2002 90 Td5 Station Wagon
30th Mar 2018 7:33pm |
yeah i had that with the rover metro, If you have the budget to get the head ported and flowed, even though it turns out to be spot on. Its worth doing while its off, maybe even have a look at the bottom end too, If you can sort out a replacement head, before you replace the head gasket, then why not just send the replacement head away for work, then it would be near enough a case of plug and play but preper to go over budget though, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
31st Mar 2018 1:19pm |
It a landrover, there is no budget
I'm only planning on doing this once so I'm not going to be cutting corners. Whatever it costs then I'll get it done. I've been looking at the AMC head from Turner Engineering. It comes pre ported and flowed as far as I'm aware 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
31st Mar 2018 3:39pm |
well there is your answer there, fewer question marks the better for you. I budget 1k on my rover metros head gasket, ( it was a vvc) I did go over that by nearly 500! That was getting the daft odds and sods, but also diagnostic. Which turned out to be dirt in the inlet Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
31st Mar 2018 3:55pm |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2955 |
That looks like a nice bit of engineering George good luck with the rebuild |
31st Mar 2018 4:00pm |
