Home > Maintenance & Modifications > Different front bumpers what have you got?
Page 6 of 8 <12345678>
NickBristol
This is the bumper on my 2012 Puma. It’s the thing I’m least happy with the look of, so this thread is a bit of a godsend for alternatives.
Post #692765 12th Mar 2018 9:43am
MartinK
JOW240725 wrote:
deaallen wrote:
no i don't think it was, just checked their website out and cant see it
Uproar4x4? That's who I meant originally but still not sure its right?
Thanks for that - just looked at the Uproar one - looks like just what I had in mind - anyone here got one??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #692773 12th Mar 2018 10:26am
PumaPhil
Wales 2015 Defender 90 Puma 2.2 HT Aintree Green
boode wrote:
D44 heavy duty bumper with holes cut into it for Rigid Industries LED Driving and Fog lights
Does this have extra mounting bolts - ie 6 instead of the standard 4? I'm considering either this D44 bumper, or the First Four heavy duty bumper purely as a way of getting easily accessible, strong, recovery points (not for off roading, but to drag Defender and 2 -3 ton trailers out of wet fields).
If a bumper is 'too heavy duty', would a slow speed bump transmit all forces to the chassis, as opposed to the standard bumper taking the hit and bending. I notice that most heavy duty bumpers are built of 5 mm steel, and the chassis is 2.5mm?
Post #693881 16th Mar 2018 9:27pm
zsd-puma
It all depends on the speeds involved, what you hit and which bit takes the hit, but yes theoretically a HD bumper could increase the chances of chassis damage. On the other hand the standard bumpers are soft as anything, a light tap on the end of one pushes it up into the wing, so in this instance a HD bumper would save damage.
Post #694048 17th Mar 2018 1:41pm
PumaPhil
I see your point about preventing damage to the wing, Zsd-puma, hadn’t thought of that.
Post #694795 19th Mar 2018 10:48pm
Landlord wrote:
Wanted winch bumper to be as close to rad as possible. This one came from First 4x4
I like that a lot, like mine.
I'd be a bit concerned the plate is obscured though. No MOT issues?
If it was me and to avoid any airflow restriction I'd consider rack mounting, even if spots are slightly moved to each side.
Thumbs Up Very Happy No Guts, No Glory.
Post #694801 19th Mar 2018 11:17pm
bluebottle
I’d quite like the Twisted one with the strip type DRLs. But not for over £500!
Anyone got one and can tell me the spec of the lights please? Might ask a friend to cut the appropriate holes in my standard LR one.
Post #694808 19th Mar 2018 11:52pm
Albion
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Flat Dog HD bumper with holes for Lazer RS-4’s.
Post #694815 20th Mar 2018 5:02am
Procta
I have a FF heavy duty bumper that looks like a XS bumper with the end caps. It weighs the same weight as the bull bar!
So a lot of weight on the front, with the bull bar mounted on. People sharp think twice on pulling out at the last min I tell you! yes I have sat the bumper off a few arses too when they have decided to pull out at the last moment. Very Happy
 Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #694817 20th Mar 2018 6:10am
BigRuss
I have the same D44 bumper and can confirm it’s a standard 4 bolt fitment Russell
2011MY 110 XS USW Black
Post #694822 20th Mar 2018 6:36am
It is unlikely that there'll be any airflow issues, certainly not in the UK. I have my front plate on the grille and have never had any problems, however the fact that the A-bar is in front of the plate definitely makes that illegal. Never mind MOT issues, the driver risks getting a pull and a fine for that. On the other hand, you'd have to encounter a Policeman or VOSA official who actually cares and can be bothered to do something, and, judging by the number of vehicles you see with missing, obscured, or illegal number plates, that seems unlikely.
Post #694889 20th Mar 2018 10:23am
JOW240725
I like the Twisted one as the DRL's are further towards the ends which I prefer. I picked up a refurbished Twisted bumper from LRO Show for a fraction of the new costs.
I'm fairly certain the DRL's are just the Ring Aurora http://www.ringautomotive.com/uk/products/...ng/BRL0397 James
Instagram @suffolk_rovers
Post #694899 20th Mar 2018 10:52am
ibexman
5mm HD currently for sale
Post #694902 20th Mar 2018 11:02am
bluebottle
Cool, I’ll look into that. Cheers!
Post #695103 20th Mar 2018 11:52pm
JOW240725
Just found a new one I've not seen before... Wildcat Alloy Bumper with integrated Lazer light units
Only photo I can find but I like it. Very Bowler Whistle James
Post #698477 4th Apr 2018 11:44am
