Home > Maintenance & Modifications > Different front bumpers what have you got? |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
Thanks for that - just looked at the Uproar one - looks like just what I had in mind - anyone here got one??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
12th Mar 2018 10:26am |
PumaPhil Member Since: 26 Oct 2014 Location: Bridgend Posts: 201 |
Does this have extra mounting bolts - ie 6 instead of the standard 4? I'm considering either this D44 bumper, or the First Four heavy duty bumper purely as a way of getting easily accessible, strong, recovery points (not for off roading, but to drag Defender and 2 -3 ton trailers out of wet fields). If a bumper is 'too heavy duty', would a slow speed bump transmit all forces to the chassis, as opposed to the standard bumper taking the hit and bending. I notice that most heavy duty bumpers are built of 5 mm steel, and the chassis is 2.5mm? |
16th Mar 2018 9:27pm |
It all depends on the speeds involved, what you hit and which bit takes the hit, but yes theoretically a HD bumper could increase the chances of chassis damage. On the other hand the standard bumpers are soft as anything, a light tap on the end of one pushes it up into the wing, so in this instance a HD bumper would save damage. |
17th Mar 2018 1:41pm |
I see your point about preventing damage to the wing, Zsd-puma, hadn’t thought of that.
19th Mar 2018 10:48pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20363 |
I like that a lot, like mine. I'd be a bit concerned the plate is obscured though. No MOT issues? If it was me and to avoid any airflow restriction I'd consider rack mounting, even if spots are slightly moved to each side. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
19th Mar 2018 11:17pm |
bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705 |
I’d quite like the Twisted one with the strip type DRLs. But not for over £500!
Anyone got one and can tell me the spec of the lights please? Might ask a friend to cut the appropriate holes in my standard LR one. |
19th Mar 2018 11:52pm |
Albion Member Since: 08 Dec 2014 Location: Oxfordshire Posts: 141 |
Flat Dog HD bumper with holes for Lazer RS-4’s.
Click image to enlarge |
20th Mar 2018 5:02am |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5166 |
I have a FF heavy duty bumper that looks like a XS bumper with the end caps. It weighs the same weight as the bull bar!
So a lot of weight on the front, with the bull bar mounted on. People sharp think twice on pulling out at the last min I tell you! yes I have sat the bumper off a few arses too when they have decided to pull out at the last moment. Click image to enlarge Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
20th Mar 2018 6:10am |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
I have the same D44 bumper and can confirm it’s a standard 4 bolt fitment Russell 2011MY 110 XS USW Black |
20th Mar 2018 6:36am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17382 |
It is unlikely that there'll be any airflow issues, certainly not in the UK. I have my front plate on the grille and have never had any problems, however the fact that the A-bar is in front of the plate definitely makes that illegal. Never mind MOT issues, the driver risks getting a pull and a fine for that. On the other hand, you'd have to encounter a Policeman or VOSA official who actually cares and can be bothered to do something, and, judging by the number of vehicles you see with missing, obscured, or illegal number plates, that seems unlikely. |
20th Mar 2018 10:23am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7905 |
I like the Twisted one as the DRL's are further towards the ends which I prefer. I picked up a refurbished Twisted bumper from LRO Show for a fraction of the new costs. I'm fairly certain the DRL's are just the Ring Aurora http://www.ringautomotive.com/uk/products/...ng/BRL0397 James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
20th Mar 2018 10:52am |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
Click image to enlarge Click image to enlarge 5mm HD currently for sale |
20th Mar 2018 11:02am |
Cool, I’ll look into that. Cheers! |
20th Mar 2018 11:52pm |
Just found a new one I've not seen before... Wildcat Alloy Bumper with integrated Lazer light units
Only photo I can find but I like it. Very Bowler James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
4th Apr 2018 11:44am |
