Home > My Defender > Grafty's Td5 90
Page 66 of 124 <123 ... 656667 ... 122123124>
grafty99
Long time no see! That must have been some heavy resding Laughing
When I put the alcantara on I stupidly didn't start in the concave corners. This ment I had to stretch it into them. This seemed fine and it stuck well, however, when I got it back from the paint shop all of the corners had lifted and won't go back down Big Cry
I have a plan B through Whistle 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #693672 16th Mar 2018 6:20am
Profyaffle
Oh dear.. I will keep watching for plan B to be revealed.. I have ordered some dirt D fenders.. they look very tidy on yours Thumbs Up 1993 200Tdi Defender 90
Post #693728 16th Mar 2018 10:05am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Just wondering. Will they also fit with rock tree sliders? a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #693729 16th Mar 2018 10:08am
grafty99
That's good. They do make a good difference Thumbs Up
I don't think the fronts will. The rears would though Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #693779 16th Mar 2018 3:41pm
Tdi4
Thnx grafty.
So I’am feeling a new design project comming up. Laughing a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #693784 16th Mar 2018 3:52pm
grafty99
Laughing When I get some time I may look into it Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #693809 16th Mar 2018 5:51pm
Tdi4
Haha. I meant that I would design a front dirt defender. But if you want to do it be my guest Laughing a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #693810 16th Mar 2018 5:53pm
L110CDL
I don't think grafty has got anytime as he is full on with his vents Wink Laughing 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #693873 16th Mar 2018 9:05pm
grafty99
Today has been very frustrating. I started with what should have been a simple thermostat replacement and have ended up with almost every coolant hose off the engine Evil or Very Mad
When I removed the engine cover the EGR cooler return pipe broke (it has gone extremely brittle - like dried spaghetti). As it is rarely disturbed I hadn't discovered it until now.
To make a bit more room for the thermostat change I removed the turbo to intercooler boost pipe, lucky I did as I found this has been rubbing on the thermostat to water pump pipe and caused enough of a rub on the coolant pipe for it to need replacing.
Then I decided I would give the engine a bit of a clean as I hadn't in a while and all of the covers were off so I could access it all. I then noticed that the front cam cover was weeping and needs replacing Rolling Eyes
Anyway so I thought as there was now absolutely no coolant in the system I may as well get the webasto fitted. That has been the only thing that went right!
To top it all off there are feet of snow outside and I can't go and play in it Big Cry 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #694460 18th Mar 2018 6:08pm
Procta
i hate when you get days like that, when everything that can go wrong does! I normally just down to tools and leave it to the next day. Then things start to go better, Are you doing a picture install of the webasto fitted ? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #694500 18th Mar 2018 8:49pm
grafty99
I know! Unfortunately I don't give up when I should Laughing
As we have another couple of inches of snow forecast it doesn't look like much work will be happening tomorrow. I'll get some more pics then of the webasto install Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #694507 18th Mar 2018 9:05pm
Profyaffle
Webasto... Mmmmm.. heat... I think I'd like one of those.. I've resorted to fitting an old sock over the gear knob.. it's an alloy one so it's freezing in this weather..... Many moons ago I fitted a Kenlowe hot start to my TD 90.. that was pretty good although it had to be plugged into the electricity to run..
Sounds like you've had one of 'those' days.. at least you've found faults before they caused you problems... looking forward to seeing Webasto fitting pics.... Very Happy 1993 200Tdi Defender 90
Post #694551 19th Mar 2018 12:50am
grafty99
I've never thought of putting a sock on my knob.......
Mines not metal though so that's probably why Laughing
I'm looking forward to texting the defender and then arriving at it nice and warm!
It'll also be able to heat the coolant on a cold start so will get up to temperature quicker Mr. Green 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #694624 19th Mar 2018 12:50pm
L110CDL
When my knob was silver i found the best thing was an old ipod cover Wink but i went back to the original knob's and they are good in the hot or cold weather and don't have to worry about the coldness anymore Very Happy 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #694770 19th Mar 2018 9:30pm
grafty99
Nothing worse than a frosty knob by the sound of it Shocked Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #694782 19th Mar 2018 9:55pm
