Home > My Defender > My SVX Got a New Big Brother |
CR Member Since: 28 Jan 2010 Location: Ireland Posts: 947 |
yep the centre of the grille was painted satin black to match the wheels and the sides in santorini
same as the body |
23rd Apr 2011 8:34am |
mrandmrsh Member Since: 31 May 2010 Location: Huddersfield Posts: 692 |
So the Boost alloys are soft as sh!te and it appears the SVX wheels are not much better which I understand are basically same as the optional 'upgrade' from Boosts. ZUs look more attractive by the day Stunning 110 though |
23rd Apr 2011 12:23pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5012 |
The harsh chemicals that are used to clean cars and wheels don't help - takes the mud off but strips off any protective layer and corrodes anything left unprotected. See what simple Fairy liquid will do to your windscreen wipers in no time at all
Go for the gentler products that are kinder to your hands as well I don't use detergents very often, just wash off with water most of the time - no wonder I stink |
23rd Apr 2011 12:36pm |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
hi CR awesome truck
just a couple of questions if I may. Having looked at a few ropey pre Jul 08 examples I'm veering towards new but can't get past the 2k tax disc thing our lovely Green Party brought in (bless their f*** hearts !) Reading your posts has given me a perhaps naive glimmer of hope that there might be a way around this. I also want a 7 seat SW but am not business registered or self employed. Despite the N1 classification does this mean I will still be paying the full wack as per passenger vehicles or not. You've obviously done the research and got through the usual civil service red tape in order to fight your case. Also that's one hell of a registration you've got. Can a certain number be pre - ordered. I'm guessing it wasn't pot luck that you ended up with all the ones ! Good luck with the new motor ! |
23rd Apr 2011 8:20pm |
RUST.
The SVX has rust on all the roll cage bolts, the mud flap hangers, the chassis, the rear step bumper, the bolts and hangers have already been replaced once as have the mirror arms under warranty. The dealer is doing them again as goodwill !!!! and also replacing the step bumper. 3 of the step bumpers have come in damaged for the 110 so have not been fitted. I have yet to resolve the chassis rust, the top surface of the decals is starting to come off from the layer with the double sided tape. The SVX Wheels are 100% perfect after 30k KM. |
24th Apr 2011 4:29pm |
ElDoc Member Since: 25 Apr 2011 Location: Ecuador Posts: 13 |
Hi CR great modifications that you made on your SVX I have a 110 SVX too in South America do you know how many 110 the JLR made in total, I try to research how many comes to South America, how I know what number is mine.
Best, El Doc |
26th Apr 2011 12:15am |
El Doc
The 110 is not a SVX it is a standard 110 with bits added, my SVX is a 90 soft top. Only the UK cars got a number in Ireland there are about 5 90 SVX soft-tops 2 90 SVX estates and 1 110 SVX estate do you see many defenders at home ? Cheers CR |
26th Apr 2011 10:49am |
Hi CR,
Thanks for write, your 110 have a great tune up, when I saw the picture again I can check that is not a SVX because the rear lights, you car looks awesome. Here in Home we can see few Defenderīs not too much and is easy to find some Landy series I,II and III still running. I would like to establish contact with somebody in UK to obtain the Info here in my country the dealer only import 2 SVX 1 90 and mine 110, I just check in Topix and I obtain the date when it was made and the dealer code. Best, El Doc Actual Defender 110 SVX Past Defender 90 Tomb Rider 2001 Defender 90 TD5 Black Defender 2002 |
26th Apr 2011 7:42pm |
Fitted clear lenses on the back, under cubby box and Startech steering wheel ,both really great pieces of kit
from Germany. Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
29th Apr 2011 4:19pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3639 |
under cubby box??
29th Apr 2011 5:34pm |
www.nakatanenga.de
29th Apr 2011 6:06pm |
what dealer did you buy it from CR?
30th Apr 2011 6:01pm |
Rossy
I will contact you with details CR |
1st May 2011 7:43am |
I brought thier glove box direct from them in Germany and had it posted to the uk great bit of kit also top quality other bits and bobs on the website, due to translation issues I had to phone them up and speak with them directly, the boss is contactable through this web site
1st May 2011 8:12am |
