![]() | Home > My Defender > Introducing Buggsy my 110 TD5 |
![]() ![]() Yea need to look into the possible injector issue I will have a play tomorrow and see if I can find an issue, it may be the loom as it did have some oil in it before I cleaned it, New one should be here early next week so if I can’t find anything I can atleast rule that out once it’s here. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10896 ![]() ![]() |
Nice one you got Buggsy going Mash
![]() ![]() I bet that was great when she started up ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Well today I thought I would reprogram the injectors and let the engine come upto temp as I bleed the cooling system, smoke was minimal on tickover and it seemed to be ok, a quick spin produced loads of smoke on acceleration, ok slow down to a trundle only gone a few 100m so far then total loss of power and a locked engine
![]() ![]() Anyone got a spare 15p they want to get rid of? ![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5244 ![]() ![]() |
what a pain in the arse! I have a spare 15p
![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
Nope it is official I am envious... Fed of working by torchlight after work... in the cold... ![]() |
Hi Mash. Although mixing green and black injectors will get you home I would suggest that they shouldn't be used long term due to the different pressures they work at; Black at 1500kPa (earlier 10p engine) and green at 1750kPa (later 15p and newer engines). If I recall correctly the green injectors have a longer range of movement in the plunger as well, for better efficiency and power. Best get yourself a couple of replacement green injectors. Also, even if the injectors are not coded to the ECU the engine will run, but not very well; lumpy at idle, slow throttle response and less top end... Check the idle error readings. Should be between -10 and +10 anything over that indicates there is something amiss. |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
The engine lockup could be an idler or the alternator, don't think the worst just yet
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Cheers Geobloke
![]() Yea it could be Grafty, I wasn’t really in the mood to whip off the belt yesterday but it’s on the list of to do things today. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Cheers Procta ![]() ![]() Whipped the aux belt off and the rocker cover, and after hanging off the knuckle bar attached to the crank the engine is locked solid, so new plan is buy a replacement engine to get Buggsy up and running then split my block and investigate with a possible option of a rebuild with upgrades ( after Buggsy is fully sorted and Maggie is also). Anyone ever think they have too many projects?...................... Na me either ![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
What's better than 1 project? well 2 of course, then not having a 3rd would just be rude and the forth keeps the others company whilst they are waiting in line...
![]() Or at least that is how it is in my mind... ![]() |
Well I am upto 4 projects not including the 2 running projects I have
HK07 Member Since: 15 Dec 2016 Location: Hampshire Posts: 751 ![]() ![]() ![]() |
Wow, you the man Mash.
One's enough for me!!! 2007 90 Puma - Love it - Best car I have ever owned. 1989 Ninety 200tdi - Love it - Second best car I have ever owned. 1951 80" Series 1 - Love it - Third best car I have ever owned. |
My mate in South molton is breaking a 2004? Disco 2 if that of any use Mash? 2002 90 Td5 Station Wagon
