Home > Puma (Tdci) > Front washer jet
Page 2 of 3 <123>
Morepower
New Zealand
Call Brendan at 4x4 Overlander.... You can get these!!!
https://www.nakatanenga.de/en/detail/index/sArticle/5623
If mine ever pops it's clogs then this is whats replacing it... I'd like to fit one to each of the Defenders, However... "If it ain't broke don't fix it" comes to mind... WHEN it does brake, I can justify it to the wife as an 'upgrade'... just remember to leave it broken for a few days to annoy her.. Rolling with laughter
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #674328 30th Dec 2017 7:17am
agentmulder
Kuwait
zsd-puma wrote:
it's easy to replace on a Puma, but idealy you do need someone to hold the jet on the outside while you do up the nut inside.
If you remove the windscreen, you can do the nut up holding the nozzle on your own.
Optionally, and in a roundabout way, you can just remove the windscreen and leave it at that.
Laughing
(sorry, just in one of those moods tonight) Solved the bowel problem, working on the consonants...
Post #674339 30th Dec 2017 8:54am
agentmulder
Kuwait
Lightningtweeds wrote:
https://www.fleetnews.co.uk/amp/news/2011/2/28/kwik-fit-reveals-confusion-between-engine-coolant-and-screenwash/38991/
"the majority (60%) of motorists are unaware that mixing up the two liquids could be harmful to their car."
Shocked Solved the bowel problem, working on the consonants...
Post #674340 30th Dec 2017 8:56am
zsd-puma
https://www.google.co.uk/url?sa=t&source=web&rct=j&url=https://www.fleetnews.co.uk/amp/news/2011/2/28/kwik-fit-reveals-confusion-between-engine-coolant-and-screenwash/38991/&ved=0ahUKEwiPg_L9urDYAhVDJMAKHZ9DCCEQFggfMAE&usg=AOvVaw2S2FJRB-_qZ6lJHsZafGp1&ampcf=1
Yes but you didn't use the term 'engine coolant' did you, you just said don't put 'antifreeze' in your screenwash. If you're going to be a pedant, you need to get your terminology correct. Laughing
Antifreeze isn't engine coolant, but engine coolant and screenwash are both antifreeze.
I'm actually tempted to find an old banger, just to see what it actually does.
Post #674380 30th Dec 2017 11:56am
Shocked
What I find shocking is that we let people who are that stupid drive about in cars.
Post #674382 30th Dec 2017 12:05pm
zsd-puma
How many people top up their brake fluid reservoir when the screenwash runs out.... Shocked
I did stop someone from doing that once..... It's probably why most cars these days everything is covered in plastic covers under the bonnet. Laughing
Post #674397 30th Dec 2017 1:04pm
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
......these are the same people that are paying £65,000 for a Defender?
Post #674398 30th Dec 2017 1:26pm
nitram17
Tim
Try TMD http://tmdtuning.com/shop/billet-washer-jet/ and there is a sale on !
Post #674402 30th Dec 2017 1:56pm
zsd-puma
Very likely so! Laughing
Post #674496 30th Dec 2017 8:13pm
Vitesse
Thanks to all. I received the new washer jet off eBay. Was in a Bearmarch package from the seller.
Anyway, I detached ( with a little engineering!!! ) the threaded part off the new assembly, and managed to click the new nozzle onto the stub sticking out the front of the bulkhead. Little touch of glue and all sorted. Thumbs Up and I now have a good washer mix to hopefully stop any more freezing water Embarassed 2015 90 XS Santorini Black
Post #675286 2nd Jan 2018 10:44pm
Lightningtweeds
Therein lies your problem... by seperating the two parts you have weakened the female part which will cause it to pop off sometime in the future. The nozzle part can be bought seperately from LR and will stay on longer.
Post #675304 3rd Jan 2018 5:44am
geobloke
Matt90 wrote:
Would have thought you can get a replacement nozzle quite easily, there was a post to an upgraded 5 or 6 headed replacement version that I can’t find a link to but while your fitting a new one you may as well upgrade it as the original is pretty poor
That would be Optimal - http://optimillraceproducts.com/product_in...cts_id=135
Post #675351 3rd Jan 2018 11:16am
Just been reading though this thread.
I have a new genuine washer jet to go on, and centre dash removal is no problem for me as I'll have it out anyway soon.
I have the whole new assembly, obviously the water pipe needs to come off first.
However, after that the retaining nut is rather difficult to get at.
What have you all been using to remove and re-tighten the nut?
Looking at it with the ducting pipes in the way, I don't think a ring spanner would fit in in there.
A deep socket with a UJ might however at an angle.
I did try remove the HU rear support screws to remove that instead but LR seemed to have the most ridiculous fixing system for that.
Plastic screws and rivnuts that spin if I remember rightly.
Thumbs Up Chillin In The Backwoods🇬🇧🇺🇸
Post #806218 14th Dec 2019 7:39pm
Remove the HU rear support and bin it (it's useless), then work through the radio aperture. Use a deep socket or crowfoot socket.
Post #806243 14th Dec 2019 11:25pm
Thanks Blackwolf -I have those so I’ll give that a go.
On the day I took a look at it with the dash out it looked a bit of a pain so I didn’t bother on that occasion.
I will be taking the centre dash out again shortly so I’ll have the opportunity to get it done. Chillin In The Backwoods🇬🇧🇺🇸
Post #806287 15th Dec 2019 11:55am
Page 2 of 3 <123>
