Home > Puma (Tdci) > Front washer jet |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 |
Call Brendan at 4x4 Overlander.... You can get these!!!
https://www.nakatanenga.de/en/detail/index/sArticle/5623 If mine ever pops it's clogs then this is whats replacing it... I'd like to fit one to each of the Defenders, However... "If it ain't broke don't fix it" comes to mind... WHEN it does brake, I can justify it to the wife as an 'upgrade'... just remember to leave it broken for a few days to annoy her.. Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
30th Dec 2017 7:17am |
"the majority (60%) of motorists are unaware that mixing up the two liquids could be harmful to their car." Solved the bowel problem, working on the consonants... |
30th Dec 2017 8:56am |
Yes but you didn't use the term 'engine coolant' did you, you just said don't put 'antifreeze' in your screenwash. If you're going to be a pedant, you need to get your terminology correct. Antifreeze isn't engine coolant, but engine coolant and screenwash are both antifreeze. Click image to enlarge I'm actually tempted to find an old banger, just to see what it actually does. |
30th Dec 2017 11:56am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17519 |
What I find shocking is that we let people who are that stupid drive about in cars. |
30th Dec 2017 12:05pm |
How many people top up their brake fluid reservoir when the screenwash runs out....
I did stop someone from doing that once..... It's probably why most cars these days everything is covered in plastic covers under the bonnet. |
30th Dec 2017 1:04pm |
Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461 |
......these are the same people that are paying £65,000 for a Defender?
30th Dec 2017 1:26pm |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
Try TMD http://tmdtuning.com/shop/billet-washer-jet/ and there is a sale on ! |
30th Dec 2017 1:56pm |
Very likely so! |
30th Dec 2017 8:13pm |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 387 |
Thanks to all. I received the new washer jet off eBay. Was in a Bearmarch package from the seller.
Anyway, I detached ( with a little engineering!!! ) the threaded part off the new assembly, and managed to click the new nozzle onto the stub sticking out the front of the bulkhead. Little touch of glue and all sorted. and I now have a good washer mix to hopefully stop any more freezing water 2015 90 XS Santorini Black |
2nd Jan 2018 10:44pm |
Therein lies your problem... by seperating the two parts you have weakened the female part which will cause it to pop off sometime in the future. The nozzle part can be bought seperately from LR and will stay on longer.
3rd Jan 2018 5:44am |
That would be Optimal - http://optimillraceproducts.com/product_in...cts_id=135 |
3rd Jan 2018 11:16am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20552 |
Just been reading though this thread.
I have a new genuine washer jet to go on, and centre dash removal is no problem for me as I'll have it out anyway soon. I have the whole new assembly, obviously the water pipe needs to come off first. However, after that the retaining nut is rather difficult to get at. What have you all been using to remove and re-tighten the nut? Looking at it with the ducting pipes in the way, I don't think a ring spanner would fit in in there. A deep socket with a UJ might however at an angle. I did try remove the HU rear support screws to remove that instead but LR seemed to have the most ridiculous fixing system for that. Plastic screws and rivnuts that spin if I remember rightly. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
14th Dec 2019 7:39pm |
Remove the HU rear support and bin it (it's useless), then work through the radio aperture. Use a deep socket or crowfoot socket.
14th Dec 2019 11:25pm |
Thanks Blackwolf -I have those so I’ll give that a go.
On the day I took a look at it with the dash out it looked a bit of a pain so I didn’t bother on that occasion. I will be taking the centre dash out again shortly so I’ll have the opportunity to get it done. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
15th Dec 2019 11:55am |
