Home > Puma (Tdci) > Front washer jet
Page 1 of 3 123>
Vitesse
Front washer jet
HI,
The front washer jet appears to have disappeared overnight! I now have just a stub sticking out the front. Does anyone know if the washer nozzle has perhaps become unclipped and fallen off or has it been vandalised?? Can I get just the nozzle assembly or is it a more complex job behind the dash? Thanks for your help to this rather bizarre issue! Thumbs Up
Brian. 2015 90 XS Santorini Black
Post #674077 29th Dec 2017 12:40pm
Matt90
United Kingdom 1990 Defender 90 2.5 TD HT Bronze Green
Would have thought you can get a replacement nozzle quite easily, there was a post to an upgraded 5 or 6 headed replacement version that I can’t find a link to but while your fitting a new one you may as well upgrade it as the original is pretty poor
Post #674080 29th Dec 2017 12:57pm
Vitesse
Thanks..will take a look about asap.. Thumbs Up . 2015 90 XS Santorini Black
Post #674087 29th Dec 2017 1:36pm
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
The nozzle bit pops off in freezing weather. There is a thread on the site regarding options to replace.
Post #674095 29th Dec 2017 1:56pm
Vitesse
Thank you! Thumbs Up 2015 90 XS Santorini Black
Post #674100 29th Dec 2017 2:20pm
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
The bit that pops off is factory available part and a wee drip of superglue and a tap with a hammer saves stripping the dash. Dont buy the complete nozzle and pipe as removing the part you need weakens it and it will pop off again.
Post #674101 29th Dec 2017 2:31pm
Last year the complete nozzle was a fraction of the cost of the part that pops off on its own Shocked
On a Puma, you can replace the whole nozzle if you remove the centre panel of the dash (although it is a bit of a fiddle), you do not have to remove the entire dash.
The 6-jet upgrade is made by Optimill and is excellent but pricey.
Post #674116 29th Dec 2017 3:20pm
Vitesse
THanks all.... I wasnt using any antifreeze! So that explains a lot. Rolling Eyes
Have ordered the parts and will sort in time! Thumbs Up 2015 90 XS Santorini Black
Post #674128 29th Dec 2017 4:02pm
lohr500
Useful tip for everyone, thanks Blackwolf.
I happened to spot the washer jet behind the centre panel last week whilst I had the panel removed for some other work I was doing. I made a mental note that it looked as though it could be replaced if needed. Good to know this is the case.
Post #674166 29th Dec 2017 5:32pm
zsd-puma
it's easy to replace on a Puma, but idealy you do need someone to hold the jet on the outside while you do up the nut inside. I managed to do mine by temporarily holding the outer part with masking tape while i got the nut most of the way on.
Post #674251 29th Dec 2017 9:23pm
Lightningtweeds
Antifreeze in washers not a good idea but screenwash gets a 10 from Len.
Post #674254 29th Dec 2017 9:28pm
zsd-puma
'screenwash' contains antifreeze.
Just like 'Coolant' also contains antifreeze.
Post #674264 29th Dec 2017 9:42pm
Lightningtweeds
Different stuff. Always keep antifreeze for engine and screenwash for the washer bottle.
Antifreeze is a known paint stripper.
Post #674284 29th Dec 2017 10:46pm
zsd-puma
Yes you're right "Coolant" is different stuff to "Screenwash" - but they both contain 'antifreeze'. Antifreeze being any substance that prevents freezing....
Antifreeze is still a valid term to use for both engine coolant and screenwash.
Salt is also a type of antifreeze, but i wouldn't put that in my engine coolant or my screenwash. It's a known rust promoter....
Post #674306 30th Dec 2017 12:01am
Lightningtweeds
Post #674313 30th Dec 2017 12:21am
Page 1 of 3 123>
