![]() | Home > Maintenance & Modifications > Service time - new versus old |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Yes the pumas filter seems pretty insignificant.
It does its job though. The filter housing is flimsy, ok as long as you don't drop it 😏 |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2298 ![]() ![]() ![]() |
Hello v8bobber
I thought the same when first 'confronted' with the Cartridge vs Steel (how they should look) version... ![]() 'load' the Cartridge (Filter) with new oil prior to fitting into Filter Housing Replace large Rubber O Ring around Filter Housing (also oiled) and whilst the Housing 'states' (is marked) to tighten to 25NM... press on until you reach 35NM... or she'll leak... ![]() ![]() Click image to enlarge ![]() Click image to enlarge Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 448 ![]() ![]() ![]() |
Have serviced the Puma a few times so an old hat at it but just happened to put the new filter down next to one due to go on my old 90 and really reinforced the diffence in size.
Maybe the new oil filters are made by the same people that make Mars bars as they were bigger when I was younger aswell!! |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5878 ![]() ![]() ![]() |
Playing devil’s advocate, but have you ever opened the white casing up to see how big the filter inside is, as opposed to the body? Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
They have 'form'... some things just shouldn't be messed with...
![]() ![]() Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
to be honest the paper elements aren't a new idea. It's what cars used to have before there were the spin on filters, the old metal housings for them were awful leak prone things, unlike the modern plastic ones. The spin on ones probably only have the same size element in them.
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 ![]() ![]() |
One area where the 2.2 beats the 2.4? Proper metal disposeable filter 2014 Keswick Utility 2.2
I'm not really sure it makes much difference really. Marginally less messy than fishing the element from the plastic housing but thats about all.
