Home > Maintenance & Modifications > Which sound proofing?
Page 1 of 6 123456>
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I was wondering what you guys would recommend?
The prices vary wildly on ebay, dynamat seems good but im wondering if it's overpriced as it's endorsed by Chip Foose...
I'm going to be following a similar fitout to this, but less extensive: http://www.defender2.net/forum/topic19837....+deadening 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #652884 26th Sep 2017 11:22am
Chris90V8
England 1987 Defender 90 2.5 TD XS CSW Portofino Red
Sitting on the sidelines watching this one Whistle πŸšœ. ...... . .... . .. πŸš—πŸšπŸš›πŸššπŸššπŸš—πŸš™πŸš
Post #652886 26th Sep 2017 11:25am
Kit
#canofworms? 1993 200 Tdi 90 CSW
Post #652888 26th Sep 2017 11:28am
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
I would recommend Dynamat or Silent coat. Use matting to dampen panel vibrations, and foam to absorb road noise.
Post #652889 26th Sep 2017 11:29am
bankz5152
Try Fatmat instead, very similar to Dynamat but cheaper and the quality seems identical as does performance. Did both my 90 and 110 with it, no issues what so ever to report.
It sat in my 90 for 3 years and going on a year in my 110. Definitely makes a big difference
However its best when used with multiple layers of closed cell foam* where ever you can fit it really! Then a final layer of carpet/rubber trim on top.
*When sticking down use a high temp heavy duty spray glue, not the self adhesive foam, slight bit of heat and it comes away...
Post #652890 26th Sep 2017 11:30am
I've used Silent Coat products on mine - both the damping mats and the foam isolator - and I'm really pleased with the result. I haven't finished yet as I've still got the front floor and seat box to do, but I've completed the rear tub and roof and it's transformed it from a noise level perspective.
 Darren
Post #652891 26th Sep 2017 11:31am
Stacey007
Hello
I uses silent coat with a 8MM soft cell foam over the top also.
Seems very good and £ for product seems the best
https://www.deadening.co.uk/collections/cld-sound-deadening-mats
Biggest gains I found were doors as it sound less like a tin can rattling when you shut and all over seat box and inside the battery and cubby box.
Watch this short clip... sort of sells itself
Post #652893 26th Sep 2017 11:33am
Defendermatt
Fatmat is a good cheaper alternative to dynamat, I found however that I had to double the layers of fatmat, so the cost savings are negligible.
Fatmat also doesn't seem to hold as well as Dynamat I would advise not to use on the roof that's for sure as it will begin to peel off.
Post #652894 26th Sep 2017 11:35am
Kit
Is this a good deal: http://www.ebay.co.uk/itm/Silent-Coat-2mm-...Sw241YmyaU
I just want to get rid of the vibration for now, maybe at a later date i'll try the foam 1993 200 Tdi 90 CSW
Post #652902 26th Sep 2017 12:07pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
I stripped out loads of Noise Killer ~6mm matting from the floor of mine because the foam inner was acting like a sponge and holding water. I've replaced it with 2mm unbranded Dynamat/Silentcoat type stuff from eBay which seems good for sound deadening but not as good at noise reduction. Maybe it needs another layer or a high density closed cell foam overlay? The effectiveness of a big mid-panel pad of the 2mm stuff on the door skins makes it worthwhile going to the trouble of removing the door card and plastic liner.
Post #652944 26th Sep 2017 3:36pm
Dynamat. Fit cheap stuff to a cheap car, Defender deserves quality. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #652946 26th Sep 2017 3:38pm
miker
Silent coat here, just as good as dynamat but noticeably cheaper!
Post #652956 26th Sep 2017 4:08pm
Stacey007
The only bit of my car (a 110)
I have not done is the roof... (oon and engine bay)
Are these two worth doing?
Thanks
Post #652959 26th Sep 2017 4:16pm
Grenadier
Did a full Silent Coat DIY on a 110 SW 7-seater last year. Easy to use, just time consuming. Fantastic results, especially with carpets back on top. Used Colin at the Sound Deadening Shop. Usually does a discount for Def2 members. Also very efficient delivery and helpful with any questions. Recommended. Here's what I used:
Silent Coat 2mm Mat, Silent Coat Isolator 6mm and Dodo Pro Barrier MLV.
Going to do my DCPU in the next week or so and whilst I was thorough on the SW looking to do even more on the DCPU including adding Isolator to the interior of the door cards, potentially unscrewing the floor plates and adding Isolator underneath, and (depending on advice from the forum) would take the dash off if worth it and there are places to be tackled. Finally will add an acoustic engine blanket, bonnet sound barrier and gearbox tunnel blanket:
https://www.nkgroup.co.uk/product/vehicle-...-blankets/
https://www.nkgroup.co.uk/product/land-rov...g-blanket/
https://www.nkgroup.co.uk/product/land-rover-under-bonnets/
Good luck, takes time but it's worth the effort Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #652998 26th Sep 2017 7:04pm
Chris90V8
"Finally will add an acoustic engine blanket, bonnet sound barrier and gearbox tunnel blanket"
Any side effects with the use of the blankets? I.E...poor heat dissipation? πŸšœ. ...... . .... . .. πŸš—πŸšπŸš›πŸššπŸššπŸš—πŸš™πŸš
Post #653011 26th Sep 2017 7:59pm
Page 1 of 6 123456>
