Home > My Defender > Introduction of my 110
Page 8 of 10 <12345678910>
JOW240725
Ooh looks good... but going to need a bit more information please? What's the set up? Same ride height? What's it like? Better on road but loose any articulation? Same anti roll bars?
I find the suspension all a bit baffling, but wanting ideas for when mine 'needs' replacing. Thumbs Up James
Instagram @suffolk_rovers
Post #652243 23rd Sep 2017 9:46am
John Fair
United Kingdom 2013 Defender 110 Puma 2.2 USW Santorini Black
Can't speak right now. Drowning in a car wash. Someone call the RNLI.
Post #652252 23rd Sep 2017 10:48am
John Fair
Down. High heels aren't for me 😂
Post #652281 23rd Sep 2017 3:12pm
L110CDL
Great stance Wink Thumbs Up Clayton.
Keeper.
Post #652510 24th Sep 2017 9:57pm
Pickles
Looks good to me.
Can't remember if you've had a re-map etc, so have you done anything in that regard?
Pickles.
Post #652527 24th Sep 2017 11:14pm
John Fair
Had a spare moment with the tape measure so here goes. Shocks are Fox 2.0� p series remote reservoir standard height with adjustable compression damping all around. Springs all round are �-2 inch� fronts 210lbs giving a spring drop of 20mm on the car. Rears 325lbs giving an on the car drop of 40mm. 28mm anti roll bar at rear. Cannot remember front? On softest setting the ride is fine on stiffest it�s like a mk1 mini. Both assessments when the car is empty on rural backroads. Initial turn in is much quicker and the rear delayed steering effect has gone. Body roll in long roundabouts is slight at turn in then settles to a steady lean with no increased roll if you push harder. The rag doll effect from passing trucks is gone completely. Yes it�s mapped at present but there might be other major engine work in the pipeline.
Post #652575 25th Sep 2017 9:46am
JOW240725
Sounds amazing! But so many more questions, sorry... How did you decide on the best setup? Did you go somewhere to get it all done? Can you adjust the dampers from within the cabin? I guess if you didn't want to lower you could keep original length springs?
Does look the bee's knees! Although I might come and throw some mud on it! James
Post #652632 25th Sep 2017 1:28pm
John Fair
I did it myself James. TBH the springs were partly decided from some previous experience. Only two companies could actually be bother getting back to me.
Treck Overland
LRI.
Thanks both for the effort!
I already had a pretty good idea of what I wanted to achieve but thought it might take a few tries. Oddly I�m impressed with how well it corners already so might have just fallen lucky. It even goes under my garage door without the previous couple of extra winds on the manual handle. The whole vehicle also now comes in at under 2mtrs. That was what I was hoping for.
For yourself I suppose it depends on what you want from it. We all have different objectives.
Post #652658 25th Sep 2017 3:03pm
John Fair
Spare 1/2 hour to fit the stainless track rod.
Post #656112 9th Oct 2017 5:24pm
John Fair
Then I got rained on 😱
Post #656116 9th Oct 2017 5:41pm
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
Lovely looking suspension setup Thumbs Up
Are the front Fox's remote res also? I looked at the offerings from fox before I opted for the Bilsteins, but without much info on them other than for serious off-road I didn't take the plunge.
Would be interested to hear your thoughts on them after a few progressive outings Whistle
edit: Like how you swapped out the turrets to show off the Fox's, nice touch!
Post #656121 9th Oct 2017 5:51pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
Hi Lovely looking 110 I like some of your mods and I have done a couple on my 90 back at the beginning you was not to sure about the wording on the your bonnet I am the same and now want Land Rover rather than Defender that I have now, if your 110 is Santorini black do you fancy a swop Exclamation or just change the lettering ,can this be done ?
You can see in the picture why I would want a change.
Post #656125 9th Oct 2017 6:12pm
John Fair
Matt.
My name is John, I lowered my suspension and I don�t care🤓🤓🤓
The fronts and rears are std length remote adjustable compression fox 2, it�s just the remote is mounted under the bonnet out the way on the front
. How do I find them? Well they are the 🐝 knees. The adjustable gives you the option of changing for different purposes. Something you cannot do with the b6. Close enough on cost to the bilstein switchable but with a greater range of adjustment. It does everything I want it to do and it didn�t drag its backside when I loaded it up last week. Cornering is between mighty fine and exceptionally mighty fine 🤔.
Ref my bonnet letters, well they have kind of grown on me for a backwards reason. All the rebuilds have Defender on them to look newer. Kind of like to be different with my new old look( just myself and several million others then). Thanks for the offer anyway.
Post #656133 9th Oct 2017 6:51pm
John Fair
Oh also a good friend sent me some of these in red. Not the best picture as the garage was dark.
Post #656138 9th Oct 2017 7:04pm
Defendermatt
John, my 90 is also lowered Very Happy , and I love it!
Looks like you went with the LRI springs? When I've seen them at Peterborough I've always thought they sit the defender at a good height; although went for the offerings from Alive in the end.
Glad to hear you are getting on with the Fox, I may need to have a change.... although, as the 90 is a project and the Bilsteins haven't seen the road yet, I best not Banging Head
Post #656142 9th Oct 2017 7:27pm
