![]() | Home > My Defender > Introduction of my 110 |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1866 ![]() ![]() ![]() |
Haha fair play. Might be worth a try myself and save on the cost of a fuel burning heater 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7916 ![]() ![]() ![]() |
Haha, looks slightly better than the guy who use used a Hoover tubes!!
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 313 ![]() ![]() ![]() |
Hi John, why have you removed the seals? |
John Fair Member Since: 10 May 2016 Location: Norfolk Posts: 150 ![]() ![]() ![]() |
Hi. I removed the seal to allow oil migration from the axle to the wheel bearings / drive member splines. It's something I have always done but is often open to great debate. From my personal experience the pros out weight the cons.
Pros easier service as no stripping of hubs etc just a standard axle oil change. Never changed a bearing running in oil although I suspect this is down to the effect of the cons. Cons. Keeping oil contained requires better seal maintainence and inspection. This could actually be a pro not a con as any problems show quickly and you pick up on them. I.e. Drive members working loose shows as oil misting. Rear seals leaking are exactly that and require change. ( again in day to day driving this has never happened and has only occurred very rarely in extreme use)I wonder how many people have grease seals passing unoticed and pressure wash water etc in hence bearing failure. Hope this helps. Last edited by John Fair on 21st Dec 2016 4:36pm. Edited 1 time in total |
Thanks for the response.
Its ok. Gives me something to do on the journey through Europe in the Defender. Yesterday due to a miscalculation on time we had to get a bit footy. Results are pretty consistent to the summer eurotrip. At @90 mph you only get 20mpg. Today's a bit more organised and at @ 60-70 mph were doing 31 mpg. Huge difference and gives a theoretical range of @ 550 miles in a 110 or 350 at full chat
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10955 ![]() ![]() |
Nice set off figures there John Fair
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Managed a drive around the Le Mans circuit. The width of the road makes the Defender look really small. 😞
![]() Click image to enlarge ![]() Click image to enlarge |
Wow looks great fun... So what was your best time?
![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
24 hours 😂
How are you getting on with your diffs? Please with the result? James
Gutch1985 Member Since: 15 Dec 2015 Location: Yorkshire Posts: 105 ![]() ![]() |
Loving the pictures pal
Sorry. Been busy with house stuff. The diff is working absolutely fine and has eliminated several issues, the biggest being the reliability of the standard 110 rear or lack of. If your interested in a long nose p38 conversion I should speak to Dave Ashcroft sooner rather than later. I'm sure he could be talked into making you one. Still no update on the suspension. Spring is coming!!!!!!!! ...... see what I did there😂😂😂
![]() Click image to enlarge Quiet day out. |
