Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 714 |
I haven't wired the isolation switch yet as I haven't found a connector for it yet so have just earthed them as the isolation switch only switches the earth.
The only issue with the sunroof panel I've found is that you have to be careful cutting the hole in the back of the cubby as there is very little room for error on the one edge of the panel, as the clips are right on its outer edge meaning that if you cut too much of the outer vinyl or leather, it'll leave a gap between the panel and whatever's covering your cubby. Thankfully trim glue saved the day on that one Hopefully if all that makes sense, you'll see what I mean when you get yours |
9th Sep 2017 5:50pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2187 |
Smart! Very smart! I was thinking of putting smaller switches (from a BM) on the door card and a button on the dash that just raises the rear windows to the top
9th Sep 2017 6:00pm |
That's brilliant, thanks buckblu I'll go through all that later. Ray
9th Sep 2017 6:13pm |
Bloody photobucket I've just spent ages replacing most of the early photos on this thread so it makes some sense. Only one or two missing now but what a pain they should be strung up! Ray
11th Sep 2017 4:29pm |
So the rear electric windows are all in and working but I wasn't happy with the provided mount for the switches so decided to to put them in the doors. Managed to get the surrounds for the switches in this evening
Click image to enlarge A bit neater than the switches hanging out of the door cards So as mentioned above I just need to wire the rear switches up so I have a set in the front so I can use them while driving Ray My build thread http://www.defender2.net/forum/topic17615.html |
11th Sep 2017 7:06pm |
Looks a top job
11th Sep 2017 8:24pm |
Thankyou it's another job that's temporary though. I'm just trying to get everything I want together and working so when I sort the new doors out it can put it all back together easier Ray
11th Sep 2017 9:21pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Nearly a month and no updates? (sorry make that 2!!)
10th Nov 2017 11:08am |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
I like that, wish I could trust myself with wiring anything, my 90 would like spontaneously combust if I did it 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
10th Nov 2017 11:11am |
Yeah I've been a bit busy with other things so not had a chance to do anything to it Ray My build thread http://www.defender2.net/forum/topic17615.html |
10th Nov 2017 6:39pm |
The wiring kit came with the leccy Windows so all I had to do was extend a few of them to reach the doors, it not that hard I'm sure you could do it Ray My build thread http://www.defender2.net/forum/topic17615.html |
10th Nov 2017 6:41pm |
Update just for Tiger
Finally started fitting the wiring for the heated screen and mirrors today Click image to enlarge Doesn't look much but with tidying up a few previously run wires under the dash and adding wires for the mirrors it took me a good few hours Click image to enlarge Click image to enlarge All the heated screen wiring is in and the dash back together but I'll have to connect the mirrors up tomorrow as I've run out of light and while the door trims are off I'll fix the central locking broken wire for the drivers door. Are defenders ever finished? Ray My build thread http://www.defender2.net/forum/topic17615.html |
15th Nov 2017 4:04pm |
Answering your question Ray: no.
15th Nov 2017 5:31pm |
it's like painting the forth bridge Ray
15th Nov 2017 6:06pm |
