Home > My Defender > V8 90 Project
Page 8 of 14 <123 ... 789 ... 121314>
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Cheers guys Thumbs Up hopefully I'll have the axle finished off and fitted by the end of the week work dependant. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #633544 25th Jun 2017 8:40pm
Mash
So a new week and progress can be made Very Happy
I started off with shimming the swivel housing pins and the torqued them correctly (no pics as you can't really notice anything).
Next up was to fit the tracta seals and retaining brackets:
(Proof my blood and sweat is going into this project Rolling with laughter )
Then it was onto fitting the hubs with new bearings and spacers (NOT TO SELF CHECK FOR PLAY ONCE AXLE FITTED AND STAKE NUTS) due to excessive movement when on axle stands.
With all this going so well I thought it would be rude not too add a little bit more; steering tie rod, springs and
Now 10 points for who spots my utter long moment in one of the above pics Rolling with laughter 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #633781 26th Jun 2017 8:28pm
L110CDL
Nice work mash Thumbs Up
Is it in pic 1 with the blood ? 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #633784 26th Jun 2017 8:34pm
Mash
Nope hard to spot but pic 2 does show it 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #633787 26th Jun 2017 8:42pm
Romadog
Shock absorber cups??? Question
Post #633791 26th Jun 2017 8:49pm
Mash
Nope it's a bolt on item Whistle 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #633799 26th Jun 2017 9:16pm
Mash
So times up for the answer, if you look carefully you can see I had bolted the brake pipe bracket on backwards Embarassed
However today was a new day and I had some time to play..................... so time for the new colour, I have alluded to what the colours will be and today I have put the first layer down on the bulkhead, a few small runs and a few areas I was hoping I wouldn't need to filler/sand etc will need redoing at some point but the first layer is on and once the weather dries up a little I have multiple parts to start bolting together.
D3 Hse - Fiona
Capri 2l S - Anna
Post #634468 29th Jun 2017 6:20pm
Mash
BIG NEWS Very Happy
Today I started with this:
And then spent a little time moving a few things about and ended up with this:
So next on the list is cavity wax and external wax followed by fitting the new loom. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #645729 22nd Aug 2017 7:45pm
Procta
mash you are just jammie! having access to a crane! anyway nice to see the chassis taking shape! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #645736 22nd Aug 2017 8:19pm
Mash
Sometimes work can be useful Thumbs Up I only used it because my axle was blocked in by a load of trucks that can't move. Yea slowly coming a long loads more to do yet. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #645741 22nd Aug 2017 8:28pm
dorsetsmith
good job Thumbs Up next
Post #645831 23rd Aug 2017 8:35am
Romadog
Which new loom, genuine / aftermarket ?
Post #645923 23rd Aug 2017 5:42pm
Rollin' Cool
Post #645940 23rd Aug 2017 6:55pm
Mash
Small up date today as I've been flat out and not had a lot of time,
Today I swapped over the mismatch bolt collection added to move the chassis with new shinny stainless ones, also a new aframe balljoint assembly.
The loom is aftermarket from autosparks, it comes with the modern blade fuse holder. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #647851 2nd Sep 2017 9:06pm
Hmm, are you sure that stainless bolts are correct for those applications? Unless they're properly rated I'd be inclined to stick with 8.8 mild steel ones in 'structural' locations. Darren
Post #647853 2nd Sep 2017 9:13pm
