Home > My Defender > V8 90 Project |
So after an extremely successful weekend marching around in full ww1 uniform and webbing:
Click image to enlarge I am back to work and can continue the work on the front axle, today I started on the box of shinny bits from YRM and got all my galvanised parts t-washed and etch primed, whilst these sat drying I thought I would take some very shinny calipers and turn them a more subtle black: Click image to enlarge Click image to enlarge I'm still working on the parts I have and parts I don't and the don't pile is getting bigger than the have one 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
6th Jun 2017 7:58pm |
Well today was the really exciting and enjoyable part.......
..... just kidding today was cleaning and painting bolts to start Click image to enlarge Click image to enlarge Then I started on the first hub, removing the damaged studs/clean and paint: Click image to enlarge Click image to enlarge Then came the second hub and surprise surprise it had a broken stud, que the drill and lots of patience: Click image to enlarge Click image to enlarge Click image to enlarge And sometimes I even surprise myself, just about perfect Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
13th Jun 2017 8:06pm |
ball eye
13th Jun 2017 8:35pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10379 |
Skills, I'd have missed entirely!
13th Jun 2017 9:27pm |
I very much doubt I'd ever get it spot on like that again it was completely eyeballed starting small and working up, I do love it when things actually work 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
13th Jun 2017 9:43pm |
A few more hours in the shop tonight, got some of my bits off the postie today:
First job was nice and easy, open some boxes and assemble my two new stub axles, a couple of sockets a plastic mallet and a 20t hydraulic press gave me this: Click image to enlarge Next box revieled some tracta seals so on with bolting on my shinny swivel housings and fitting the bearing races: Click image to enlarge To assist in fitting the swivel housing I utilised one of my favourite "modified" tools, used so much I think it's starting to wear out: Click image to enlarge So axle is starting to come together and I'm going through what bits I have to assemble and what have I forgotten to clean up and paint? The swivel housing pins ok que the grinder and some safety kit: Click image to enlarge Click image to enlarge Click image to enlarge Right with that sorted I'm now only missing my dirt deflectors so I loosely bolt my housings together so I don't lose any bits: Click image to enlarge So it's starting to come together hopefully I can have a rolling chassis by next week 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
15th Jun 2017 8:33pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10733 |
What talent you have got, well jel 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
22nd Jun 2017 8:40pm |
Cheers guys don't worry the next update will soon appear, I have managed to squeeze the odd bit in here and there but work is keeping me very busy
. . . . . . . . *Spoiler*..........................rebuilt axle may appear 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
22nd Jun 2017 8:48pm |
Update time, with work being busy project time has been limited but I have made a little progress:
First job was the fitting of new wheel studs to the hub, the old studs were badly damaged when the wheel fell whilst the wagon was going down the motorway: Click image to enlarge Next job was to fit my newly painted dirt deflectors and torque the stub axles to the swivel housings: Click image to enlarge Then it was onto fitting and torquing of the new brake disks ( after waiting for the bolts that I forgot to order) Click image to enlarge After all this I could inspect my diff and refit: Click image to enlarge With everything else nice and shinny it would have been rude not to paint it,Whilst that was drying I put in my new bearing races: Click image to enlarge Next job was to inspect my drive shafts prior to fitting: Click image to enlarge Then it was onto assembling the front axle as much as I can (just waiting for a spring balance so I can't test my shims) Click image to enlarge And the final job done was to turn my springs from black with white dots to black again: Click image to enlarge Click image to enlarge [/u] 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
23rd Jun 2017 7:33pm |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 |
Great progress, looks fabulous 1993 200Tdi Defender 90
23rd Jun 2017 8:26pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5146 |
looking great there mash! do the vent discs fit behind any wheel? I have after market wheels on ( weller type) so I am unsure if they will fit. My old car I had, I had to space the wheel out by 5mm. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
23rd Jun 2017 10:56pm |
Cheers for the comments guys
The wheels should fit, hopefully I will have a fulling chassis soon and can test it, if not I will have to fight my way to the back of the shed for the old pair of Wolf rims I have lurking in there. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
24th Jun 2017 8:09am |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Your doing a great job, it will be well worth all that effort your putting in 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
24th Jun 2017 9:03am |
Great pics there Mash, looks lush 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
25th Jun 2017 8:24pm |
