![]() | Home > Puma (Tdci) > Engine bay 12V Ignition hook up |
--defender-- Member Since: 22 Apr 2010 Location: South Coast Posts: 90 ![]() ![]() ![]() |
Thanks for everyones help. All suggestions taken on board and found these ideas most useful. Cheers, Zera If it ain't broke don't fix it! |
I measured the 12V to the dipped headlamp when switched to main beam and it dropped to 8V which indicates to me that it has a dim-dip relay fitted? Looking at the wiring diagram I have, it shows it as relay dim-dip R126. On my 2010 defender where is it located?? ![]() Click image to enlarge Zera If it ain't broke don't fix it! Last edited by --defender-- on 7th Jun 2017 4:04pm. Edited 1 time in total |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
If you have one, it's the tall one top right in the CJB (ie the fuse box under the dash).
Is this the relay? (attached) Zera If it ain't broke don't fix it! |
I'll take it out and try tomorrow. If it is i'll defeat its function. Many thanks for your help. If it ain't broke don't fix it! |
After all of that when I removed the relay is only had two pins (odd I'm thinking) when I took the back off it was just a shorting line between the top and bottom pins. So it looks like it dim-dip was disabled all the time after all! If it ain't broke don't fix it! |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 ![]() ![]() |
I have fitted a hella DRL that has a "smart" controller
I simply wired it to the alternator per instructions (yes permanent live The smart controller is essentially a voltage sensitive relay that turn the lights on if a charging voltage is detected. Works great |
So wire the DRL positive to alternator as permanent love
And earth to earth on a/c compressor housing Then the Parker wired to the positive low beam wire so the DRL became Parkers at night |
