Home > Puma (Tdci) > Engine bay 12V Ignition hook up |
--defender-- Member Since: 22 Apr 2010 Location: South Coast Posts: 90 |
Thanks for everyones help. All suggestions taken on board and found these ideas most useful. Cheers, Zera If it ain't broke don't fix it! |
4th Jun 2017 4:03pm |
I measured the 12V to the dipped headlamp when switched to main beam and it dropped to 8V which indicates to me that it has a dim-dip relay fitted? Looking at the wiring diagram I have, it shows it as relay dim-dip R126. On my 2010 defender where is it located?? Click image to enlarge Zera If it ain't broke don't fix it! Last edited by --defender-- on 7th Jun 2017 4:04pm. Edited 1 time in total |
7th Jun 2017 3:28pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17526 |
If you have one, it's the tall one top right in the CJB (ie the fuse box under the dash).
7th Jun 2017 3:33pm |
Is this the relay? (attached) Zera If it ain't broke don't fix it! |
7th Jun 2017 3:58pm |
I'll take it out and try tomorrow. If it is i'll defeat its function. Many thanks for your help. If it ain't broke don't fix it! |
7th Jun 2017 9:17pm |
After all of that when I removed the relay is only had two pins (odd I'm thinking) when I took the back off it was just a shorting line between the top and bottom pins. So it looks like it dim-dip was disabled all the time after all! If it ain't broke don't fix it! |
8th Jun 2017 8:00am |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 |
I have fitted a hella DRL that has a "smart" controller
I simply wired it to the alternator per instructions (yes permanent live The smart controller is essentially a voltage sensitive relay that turn the lights on if a charging voltage is detected. Works great |
6th Oct 2017 7:09am |
So wire the DRL positive to alternator as permanent love
And earth to earth on a/c compressor housing Then the Parker wired to the positive low beam wire so the DRL became Parkers at night |
6th Oct 2017 7:11am |
