Home > My Defender > Grafty's Td5 90
Page 20 of 124 <123 ... 192021 ... 122123124>
grafty99
Yeah Valeo do aero wipers too, they look pretty decent but without fitting them can't comment on their wiping performance. They are a little less chunky looking than the bosch ones Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #603444 20th Feb 2017 10:06pm
L110CDL
Thumbs Up The best Valeo mod i got on my landy is the................... clutch, its soooooo lite, just like your in a car Mr. Green Clayton.
Keeper.
Post #603450 20th Feb 2017 10:26pm
grafty99
Same here valeo clutch and DMF Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #603453 20th Feb 2017 10:35pm
L110CDL
Thumbs Up Clayton.
Keeper.
Post #603457 20th Feb 2017 10:39pm
grafty99
Well I have some rather exciting news! My dad has bought a 2 post car ramp Mr. Green this means that my defender will be in the air more than it is on the ground Laughing I already have my first job lined up for it - fitting the genuine 13 pin towing electric kit that has been sat in the workshop for months Whistle
I'm going to pick it up this weekend so will update with a couple of pictures, hopefully including installation and of course it's first use Mr. Green
Also I thought I'd post a quick picture of my defender from last Saturday Thumbs Up
1990 Vogue SE
Post #603975 22nd Feb 2017 6:54pm
Green Machine
Looking really good Grafty! And good news on the 2 post lift - that will make life a lot easier. Wheels look good without the centre caps, think I prefer them like that. Which wheel nuts are you using? Wringtons? 2005 Td5 | 90 Station Wagon | Tonga Green
Post #603991 22nd Feb 2017 7:55pm
grafty99
Cheers Green Machine Thumbs Up I'm still undecided on the wheels without centre caps, I just feel it looks a bit busy. I'll live with it for a while yet though Thumbs Up
Wheel nuts are standard with black rubber caps on them from IRB Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #603995 22nd Feb 2017 8:10pm
mk1collector
I always feel the centre caps for those wheels stick out too far but I'm not keen on the no centre cap look. Would it be possible to cut the centre caps down so they sit closer to the wheel face? Ray
My build thread
Post #604013 22nd Feb 2017 8:42pm
grafty99
That was one reason I removed them Ray but, as you say, I'm not particularly keen with them off either.
I might have a go at cutting them down. The edge is turned on them to for a lip to prevent them coming off. They fit over the centre first and then the wheels fit over the caps.
I'll have to cut them down and then dress the edge over to re form the lip. It's a while since I've used my hammer and dolly Shocked 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #604019 22nd Feb 2017 8:52pm
grafty99
I'm going up to IRB this weekend so might be able to pick up a spare set Mr. Green 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #604020 22nd Feb 2017 8:53pm
mk1collector
I didn't realise they were metal. Is there a lot of space behind the cap? Ray
My build thread
Post #604062 22nd Feb 2017 10:38pm
grafty99
Secured a second set of caps so definately going to have a play with mine. Yeah they're steel so should be fairly simple to modify.
On the rear I'd say that there is between 25 - 30mm on the front I'd say slightly less due to the drive spline and rubber cap (which I could remove).
I'd aim for the rears to protrude around 5mm from the face of the alloy. The fronts around 10mm. Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #604065 22nd Feb 2017 10:46pm
grafty99
Although I may make them equal. I'll have a good look tomorrow Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #604067 22nd Feb 2017 10:47pm
mk1collector
That sounds much better Thumbs Up Ray
My build thread
Post #604074 22nd Feb 2017 11:11pm
TVR Tommy
United Kingdom 2000 Defender 90 Td5 Heritage LE Bronze Green
Hi grafty
It a nice easy modication on the hub covers. I cut mine down and then just used the alloy to make the lip with a hammer. Looks much better.
Your 90 has moved on since I last saw it. Looks great.
Post #604090 23rd Feb 2017 6:37am
