Home > My Defender > Grafty's Td5 90 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4788 |
The seats came from IRB developments - another customer had ordered them and had a change of heart so I bought them
My current seats are standard XS Td5 seats which are the same shape as Tdi ones. This gives you an idea of what they look like (crappy image from google) Click image to enlarge As standard the xs seats are heated - which is nice. I use mine quite a bit. I find them really comfortable and have no problem driving without stopping until I need fuel 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
17th Feb 2017 8:50am |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5208 |
They nice, what are you after for yours? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
17th Feb 2017 1:46pm |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 |
Perfect thanks Grafty, speedo healer on order Ref Bogwert's query about cruise control switches, I'm planning to use a D2 switch and mount in on the column besides the wiper stalk. Should be a bit tidier than the loose switches i have hanging out below the clock currently |
17th Feb 2017 3:13pm |
No problem, I have seen D2 switches mounted on the column before, it looks smart 2002 90 Td5 Station Wagon
17th Feb 2017 5:06pm |
Just for clarity
Speed transducer (transfer box) V Speedometer in dash binnacle (speed pulse doubled for ecu to read) V Speedo healer here ECU receives pulse for cruise control etc 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
17th Feb 2017 5:08pm |
Procta PM inbound 2002 90 Td5 Station Wagon
17th Feb 2017 5:11pm |
Harry.O picture of D2 switches on a defender column (picture courtesy of google)
Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
17th Feb 2017 5:13pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10810 |
Thanks for the the mug of tea grafty99 Great to see you "both" in the flesh, had a great time 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
18th Feb 2017 8:43pm |
No problem! Thanks for popping by, nice to put a face to the name 2002 90 Td5 Station Wagon
18th Feb 2017 10:31pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
So if I buy a d2 cruise on/off switch and the set/res what do I need to do to make it all work?
Thanks in advance 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
18th Feb 2017 10:56pm |
To make it work with standard gearing all you need is;
The control switches and some basic wiring from 12v then to the switches then on to the ecu. I know this works from 2002 onwards Td5s but not sure about pre 2002. If you have taller gearing (discovery transfer box etc) then all of the above applies except you also need a speedo healer to interrupt the speed signal going into the ecu. This allows the ecu to see a slower speed that is actually occurring and so it stays within it's rpm vs speed parameters which it will go outside of with taller gearing. Hopefully this helps 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
18th Feb 2017 11:13pm |
Grafts that's great std box and have the 2 switches on the way 👍 It is a2003 so should be good 2008 110 2.4 XS Utility (Hagrid)
19th Feb 2017 8:20am |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 597 |
Can this be utilized with the Puma?
19th Feb 2017 2:55pm |
Ideal pj2106 yeah will work on a 2003
Stiff1 Unfortunately it won't work on a puma. You'll need a separate cruise control unit from the likes of mobilecentre 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
19th Feb 2017 3:30pm |
