Home > Td5 > Remap and mantec snorkel |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
A snorkel does cause a restriction but I doubt you would notice it. If you re do the pipework with larger diameter and have a remap then you won't notice any detrimental effect I'd have said 2002 90 Td5 Station Wagon
15th Feb 2017 6:32pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20413 |
If you remove the rain separator in the original ducting that will pretty much equalise nearly all restriction.
(But there will still be a very small amount - so little. Not enough to be of concern.) If you replace Ducting as well it'll be around the same. This is based on a standard tune but there is little difference to it if remapped. I run my Safari with rain separator removed, but standard ducting. Very little difference with or without, definitely nothing to notice. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
15th Feb 2017 6:48pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2230 |
I found less lag at speed after fitting my safari to the TD5. I run with the 'dump valve' fitted but think i removed the vortex on the air box inlet.
The safari section which passes through the wing is so much less restrictive than the stupid standard elbow. I ensured that i used the 300tdi version of the snorkel so i could get rid of that elbow as the newer td5/tdci model retains it. Steve 02' 110 TD5 Double Cab Rebuild Thread |
15th Feb 2017 8:36pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3373 |
I'm running a southdown snorkel with a BAS 170 and you don't notice any difference.
15th Feb 2017 9:57pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17417 |
I replaced my Mantec snorkel with a Nakatanenga top-entry snorkel and there is a very substantial improvement! The engine breathes much more freely, is more responsive, and revs higher than it did before.
Until you fit a properly-engineered large-bore sealed induction system, and the Nakatanenga snorkel is the only one I know of, you don't really appreciate how chronically restrictive the original Landrover "microbore" induction system is. It is unlikely that the op's snorkel/RAI will make much difference since as long as the original pipe from wing to airbox is used, this is the most severely restrictive piece. |
15th Feb 2017 10:24pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
That's why I build my own. Maybe not to everybodies liking but no restrictions.
Click image to enlarge And it is steel so my 90 can lean on it: Click image to enlarge You can't do that with a plastic side inlet type. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
16th Feb 2017 10:28am |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 329 |
Yes I like it ! Might have a go at fabricating my own as well, the mantec one is fine for a raised air intake but getting the thing to seal is very hard. I have some 4 inch exhaust pipe and a mig welder, what could go wrong ?
16th Feb 2017 3:17pm |
Could you post a few more detailed pics for me ? Inside the engine bay would be good as well.
16th Feb 2017 3:18pm |
How about this for a custom airbox?
Click image to enlarge |
16th Feb 2017 3:21pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2173 |
I am considering fitting twin snorkels (Southdown) to my TD5 for maximum air flow, looks pretty simple to do on the TD5 airbox anyway.
16th Feb 2017 8:51pm |
Pretty cool steampunk looking mod! How/where will the air filter sit? 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
16th Feb 2017 9:14pm |
Some detail pics:
Click image to enlarge Click image to enlarge Click image to enlarge I removed all the standard water catchers, But made my own in the wing. The pipe goes vertical through the top off the wing till just above the innerwing. The bottom has a small angle and on the lowest side I have a small pipe. The metal pipe were the red hose goes slips over sits about 2 cm above the btm. A garden hose is fitted to the small pipe and goes over the inner wing to the footwell area where I can tap the water off. I don't have picture off the water catcher but it really works well. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
16th Feb 2017 10:08pm |
looks good ! I might copy your idea of the water drain fitting as well. I think I will keep mine running in through the wing plate however. What internal diameter is the snorkel and the flexihose? Thanks
17th Feb 2017 9:42am |
The ID is all 80mm. Except for 10 cm below the wing were the red hose is pushed over a pipe. That is 75mm id. Roel
17th Feb 2017 2:37pm |
