Home > Td5 > Remap and mantec snorkel
Welkman
Hello,
Anyone done this? I have the snorkel fitted and am hoping to have an Alive map soon. Will I massively restrict my power by having the snorkel fitted? I am looking into making a better water tight connection to the air box as well as the stock piping is impossible to seal !
Thanks
James
Post #602052 15th Feb 2017 7:29pm
grafty99
A snorkel does cause a restriction but I doubt you would notice it. If you re do the pipework with larger diameter and have a remap then you won't notice any detrimental effect I'd have said Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #602053 15th Feb 2017 7:32pm
If you remove the rain separator in the original ducting that will pretty much equalise nearly all restriction.
(But there will still be a very small amount - so little. Not enough to be of concern.)
If you replace Ducting as well it'll be around the same.
This is based on a standard tune but there is little difference to it if remapped.
I run my Safari with rain separator removed, but standard ducting.
Very little difference with or without, definitely nothing to notice. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #602059 15th Feb 2017 7:48pm
rallysteve
I found less lag at speed after fitting my safari to the TD5. I run with the 'dump valve' fitted but think i removed the vortex on the air box inlet.
The safari section which passes through the wing is so much less restrictive than the stupid standard elbow. I ensured that i used the 300tdi version of the snorkel so i could get rid of that elbow as the newer td5/tdci model retains it.
Post #602092 15th Feb 2017 9:36pm
camelman
I'm running a southdown snorkel with a BAS 170 and you don't notice any difference.
Post #602139 15th Feb 2017 10:57pm
I replaced my Mantec snorkel with a Nakatanenga top-entry snorkel and there is a very substantial improvement! The engine breathes much more freely, is more responsive, and revs higher than it did before.
Until you fit a properly-engineered large-bore sealed induction system, and the Nakatanenga snorkel is the only one I know of, you don't really appreciate how chronically restrictive the original Landrover "microbore" induction system is.
It is unlikely that the op's snorkel/RAI will make much difference since as long as the original pipe from wing to airbox is used, this is the most severely restrictive piece.
Post #602158 15th Feb 2017 11:24pm
roel
That's why I build my own. Maybe not to everybodies liking but no restrictions.
And it is steel so my 90 can lean on it:
You can't do that with a plastic side inlet type. Mr. Green Roel
2003 90 Td5 (2009-now)
Post #602212 16th Feb 2017 11:28am
Welkman
Yes I like it ! Might have a go at fabricating my own as well, the mantec one is fine for a raised air intake but getting the thing to seal is very hard. I have some 4 inch exhaust pipe and a mig welder, what could go wrong ? Smile
Post #602287 16th Feb 2017 4:17pm
Welkman
Could you post a few more detailed pics for me ? Inside the engine bay would be good as well.
Post #602289 16th Feb 2017 4:18pm
Welkman
How about this for a custom airbox?
Shocked
Post #602291 16th Feb 2017 4:21pm
bankz5152
I am considering fitting twin snorkels (Southdown) to my TD5 for maximum air flow, looks pretty simple to do on the TD5 airbox anyway.
Post #602405 16th Feb 2017 9:51pm
grafty99
Shocked
Pretty cool steampunk looking mod! How/where will the air filter sit? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #602416 16th Feb 2017 10:14pm
roel
Some detail pics:
I removed all the standard water catchers, But made my own in the wing. The pipe goes vertical through the top off the wing till just above the innerwing. The bottom has a small angle and on the lowest side I have a small pipe. The metal pipe were the red hose goes slips over sits about 2 cm above the btm. A garden hose is fitted to the small pipe and goes over the inner wing to the footwell area where I can tap the water off.
I don't have picture off the water catcher but it really works well. Roel
Post #602444 16th Feb 2017 11:08pm
Welkman
looks good ! I might copy your idea of the water drain fitting as well. I think I will keep mine running in through the wing plate however. What internal diameter is the snorkel and the flexihose? Thanks Smile
Post #602530 17th Feb 2017 10:42am
roel
The ID is all 80mm. Except for 10 cm below the wing were the red hose is pushed over a pipe. That is 75mm id. Roel
Post #602600 17th Feb 2017 3:37pm
