![]() | Home > Td5 > Remap and mantec snorkel |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 333 ![]() ![]() |
Cheers Roel
38 extra bhp on top of the standard 120/130 ish is a good jump. Ray
That is a nice difference, the only problem with a tune is that you never can feel the difference, so you get used to that in a week or so and then it is normal.
I have a powerbox and made it work only on full throttle and I can switch it on and off sperately. The book says I can get 168 hp from my 122 hp td5, I don't belief that because I use the standard intercooler so I think I will be somewhere in the 150 ish. If I switch it on under full accelaration it is a strong push in the back. So Yes it makes a real difference but you will get used to that very quickly. ![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
arran jones Member Since: 21 Nov 2016 Location: south west Posts: 728 ![]() ![]() |
Cool, thanks 4 the advice
Is it a remap of a good supplier? Like with almost everything for a Land Rover you have good parts and you have not as good parts. If you feel the weight difference between an original CV and a Britpart CV you know which one to take. With a tune it is more dificult to compare.
Check the price difference between what you have been offered and some of the sponsors here. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
I've got the prices from,
Avon Tuning and Gloucester LR Both same price £250 |
