Home > Puma (Tdci) > Can anyone explain
Page 1 of 3 123>
Crofter
United Kingdom 2009 Defender 110 Puma 2.4 USW Baltic Blue
Can anyone explain
The half shaft went on my Landy last week, Both half shafts have gone in the last 6 months at approx. 38000/39000 miles.
When the half shaft has gone there appeared to be no drive. I was lucky as once it went at my local garage whilst I was driving it and once at home.
I thought the fact the Landy has 4 wheel drive would have meant it could still be used in say a limited mode, however there
was no drive.
Can anyone explain why that was the case?
Is 38/39000 miles around the normal for these to go?
Should I have had these changed out a set interval?
Sorry just trying to get my head round this.
Post #599292 5th Feb 2017 5:08pm
RobKeay
You could probably have driven if you put it in diff lock.
Mine went at about 40k. Had the new ones out the other day and the ends were already rusty after 25k miles and less than 12 months old. I've put copper slip on them not sure if that's the right thing to do.
Post #599296 5th Feb 2017 5:17pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
The centre diff in the tbox is open, if you snap a halfshaft you need to select diff lock, this locks the tbox diff splitting power equally front and rear. When it is open/unlocked the power/drive will travel the easiest route normaly to the snapped shaft as it just spins in the axle casing. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #599299 5th Feb 2017 5:19pm
Technically (under extreme conditions) you normally have one wheel drive.. Without abs/traction control.
With the centre diff lock, you get 2 wheel drive.
Only with centre diff lock and 2 diff locks locked- ARB air lockers for example do you get true 4 wheel drive.
Post #599321 5th Feb 2017 6:11pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Have a look at this video, where it is very well explained and shown with different Land Rover types with different transmissions:
The answer to your question is in the first 20 minutes - this is must-know info for every Defender driver IMHO. The rest is about offroad driving. Good to know if ever you're in a tight spot, but not crucial you if tend to stick to the asfalt.
Hope you enjoy it.
Post #599469 6th Feb 2017 12:12am
Crofter
Thanks I think that answers my questions.
Rather than the half shaft snapping it seems it is the splines that go either on the collar/hub or shaft at the wheel end.
Is that what the rest of you find?
Post #599532 6th Feb 2017 11:57am
Fifth Horseman
The splines in the drive members do seem to wear, not helped by these being assembled dry from the factory.
This is the rear shaft on my previous Defender at 3 years old:
When you replace the shaft and/or the drive member be sure to lubricate the splines.
Landrover seem to have a problem understanding the need to provide lubrication for splines as witnessed by the growing number of gearbox adaptor shaft failures - at least the drive members are easy to check and lubricate.
Post #599712 6th Feb 2017 9:14pm
grafty99
I think landrover reintroduced 1 piece rear shafts for all models in 2015 Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #599717 6th Feb 2017 9:23pm
Devon-Rover
Quote:
grafty99
Post #5997176th Feb 2017 9:23pm
From VIN GA481822.. Circa 2016 MY
And as seen Here Fitted under warranty By Land Rover after my started wearing after 20K.
[/quote]
Post #599719 6th Feb 2017 9:28pm
grafty99
1990 Vogue SE
Post #599721 6th Feb 2017 9:30pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
Its down to the middle diff - I remember a demo at Billing years ago where a 90 had one wheel jacked up, was switched on, put into gear, and it just sat there with the jacked up wheel rotating, and going nowhere! Euro-Leafing to infinity and beyond.....
Post #599909 7th Feb 2017 7:14pm
explore
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
Just need to take drive flanges off and lube splines with plenty of grease, think Land Rover build them up dry, half shafts wear quicker then the flang
Post #604656 24th Feb 2017 11:08pm
Does anyone have the parts numbers to hand for these 1 piece shafts?
Post #604685 25th Feb 2017 8:46am
ChrisWoods
United Kingdom 2009 Defender 110 Puma 2.4 USW Aintree Green
Are Landover really doing one piece shafts again? Makes sense I suppose, one less place to go slack and fret until failure. 2009 2.4TDCi XS Utility Wagon.
Post #604687 25th Feb 2017 8:51am
walfy
My rear shafts were replaced with 1 piece versions a few months ago due to wear. So it seems like common practice for dealerships now 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #604694 25th Feb 2017 9:40am
Page 1 of 3 123>
