Home > Puma (Tdci) > can sound like bag of spanners when cold accelerating
Page 3 of 3 <123
neverin
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Update
HAve been waiting to post a progress report.
Not perfect all the time.
Sometimes the engine sounds perfect and quiet. Other times there is still a Detonation type rattle, more often than not now.
THere must be something else wrong, but it seems to drive ok and have enough power. Its just the detonation noise.
Post #590333 5th Jan 2017 9:34am
Vmesch
Belgium
Has anyone noticed some kind of power increase when experiencing the 'bag of spanners' phenomenon? I was driving home last day and was cruising at constant speed when it occurred (cold motor) and it was speeding up without changing the position of my foot on the pedal.... This could be pointing towards air intake problem? puma 2.2 MY2013
[:O]===[O:]
Post #590464 5th Jan 2017 6:44pm
neverin
ive often wondered about air temperature as the engine seems stronger the colder the weather?
Post #590489 5th Jan 2017 7:41pm
Vmesch
Belgium
just same thoughts from my side: the colder the weather, the smoother it runs! Thumbs Up puma 2.2 MY2013
[:O]===[O:]
Post #590491 5th Jan 2017 7:43pm
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Colder air means it's more dense, packed with more oxygen per cubic meter, therefore the engine is getting more oxygen for any given speed.
Same principle as what your intercooler is trying to do.
Cheer
Andy
Post #590497 5th Jan 2017 7:52pm
neverin
so will a more capable intercooler make the engine run better and more consistent?
Post #590612 6th Jan 2017 7:59am
ROBBONTHEROCK
Absolutely, but there is a trade off between air cooling and creating a restriction on the air flow which effectively starves the engine of air.
So what I'm trying to say is an intercooler is a carefully designed component to maximise air flow for a given temp drop.
Check out the BAS airflow, there is quite a bit of info out there on that.
Cheers. Andy.
Post #590613 6th Jan 2017 8:08am
neverin
might sell it a buy a td5?
Post #592133 11th Jan 2017 1:25pm
Dreamweapon
Scotland 2008 Defender 110 Puma 2.4 HT Cairns Blue
Try changing onto an "Ultimate" or "Premium" diesel for a couple of tanks, or adding a good quality diesel additive. Always helps mine when it gets too rattly.
Post #592762 13th Jan 2017 12:22pm
neverin
I occasionally drive a luton van which is an 07 plate with a puma 2.4.
That makes the same detonation noise although its not as prominent due to having more sound insulation than my defender
Post #592766 13th Jan 2017 12:42pm
neverin
What do you class as a good quality diesel additive?
Post #592767 13th Jan 2017 12:43pm
Page 3 of 3 <123
