Home > Puma (Tdci) > can sound like bag of spanners when cold accelerating
Page 2 of 3 <123>
neverin
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hello Pinky, can you post your progress and results when you have changed your vcv?
Post #567003 27th Sep 2016 1:26pm
neverin
Hi X4SKP,
was your screenshot of an iphone? what is the software?
Post #567006 27th Sep 2016 1:29pm
X4SKP
Hi neverin.... Not mine, just found on YouTube SKIP
Post #567061 27th Sep 2016 4:46pm
Pinky
England 2011 Defender 110 Puma 2.4 DCPU Baltic Blue
Thanks, I'll have a go! Even with my pork sausage fingers Laughing
Post #567081 27th Sep 2016 5:42pm
Pinky
neverin
It might be a while, I have just had notice that I am in hospital for hand surgery next week and don't think I'll have time to change it before I go in Big Cry
It may be some weeks before I can use my hand again but I'll keep you posted.
Post #567405 28th Sep 2016 5:55pm
Saley
United Kingdom 2009 Defender 110 Puma 2.4 CSW Bronze Green
Puma engine rattle
New member. I also had this problem on 2009 110 County 2.4. Would sometimes go a few weeks and not do it but when it did it was after about driving a few minutes from cold and usually changing from third to fourth. Sounded like engine was dry or bad case of tappets. Back off throttle until engine quietens then okay. Noise not occurred since fitting new electrical control valve ( that may not be the correct term for it ) in the air filter.
Post #567462 28th Sep 2016 9:29pm
X4SKP
Hello Saley
Interesting... Shocked
Am I (we) joining a dot here that is relevant...?
I have had the Engine Warning Light (MIL Light) come on now twice in 2 years
bought a scangaugeII to read the fault code...
P1103 Mass Air Flow Sensor In Range But Higher Than Expected D* d M* MAF
This clears itself after around 6 cycles of starting / stopping the engine...and I have done nothing else to
resolve this 'issue' (if indeed it is an issue / problem)...
My understanding is that this 'sensor' (probably some sort of thermocouple device) is in the air inlet side of the air filter housing...
Is this your 'electrical control valve'...'in the air filter'...you refer to...Question
and could this be a factor in the 'bag of spanners mystery'... or as you say just a coincidence...Question
Any insight D2N... Question SKIP
Post #567573 29th Sep 2016 2:17pm
neverin
iv ehad the mass air flow sensor changed and the egr valvle because the engine management light was coming on. it hasnt resolved the nag of spanners issue though.
Post #567617 29th Sep 2016 5:20pm
vaucluse
2007 Defender 110 Puma 2.4 SW Java Black
I suffered this 'bag of spanners' for four years and was recently pointed to the VCV by one of the guys at Alive. Changed it a couple of weeks ago and now living with a blissfully quiet engine. Feels like a new truck!
Mark
Post #567629 29th Sep 2016 6:13pm
neverin
Hi Mark,
did you change the VCV yourself or did you get a garage to do it? i would try myself but i dont have any equipment to recode or relearn.
Post #567715 29th Sep 2016 10:02pm
X4SKP
Hi neverin...that would be my question also for vaucluse
Looking again at
it looks like its posted from the D2N site sponsor Bell Auto Services...
so one way to 'relearn' the VCV
Maybe vaucluse or BAS can add more... Question SKIP
Post #567824 30th Sep 2016 1:45pm
neverin
Can anybody confirm the part number for the VCV?
Post #568592 4th Oct 2016 12:25pm
vaucluse
Had a garage do it together with the pump and injector learn.
Post #568622 4th Oct 2016 3:20pm
dorsetsmith
Post #568627 4th Oct 2016 3:33pm
neverin
UPDATE
Had the VCV valve (Denso part) changed yesterday, along with pump relearn and pilot correction.
Now the rattly spanner and pinking noises have gone. just left with a diesel sounding engine, Great!! I also had the fuel filter changed at the same time.
well worth having done.
Just a summary of the symptoms before:(all when engine under load, sounded fine when still)
Engine sounding like a bag of spanners intermittently,
Pinking noise occasionally, bearing type noise rattling,
no faults being displayed or recorded.
Thanks for all who contributed!
Post #570816 14th Oct 2016 11:57am
Page 2 of 3 <123>
