Home > Puma (Tdci) > can sound like bag of spanners when cold accelerating |
Vmesch Member Since: 06 Dec 2014 Location: Antwerp - Lier Posts: 47 |
Has anyone noticed some kind of power increase when experiencing the 'bag of spanners' phenomenon? I was driving home last day and was cruising at constant speed when it occurred (cold motor) and it was speeding up without changing the position of my foot on the pedal.... This could be pointing towards air intake problem? puma 2.2 MY2013
[:O]===[O:] |
5th Jan 2017 6:44pm |
neverin Member Since: 26 Sep 2016 Location: worksop Posts: 47 |
ive often wondered about air temperature as the engine seems stronger the colder the weather?
5th Jan 2017 7:41pm |
just same thoughts from my side: the colder the weather, the smoother it runs! puma 2.2 MY2013
[:O]===[O:] |
5th Jan 2017 7:43pm |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 |
Colder air means it's more dense, packed with more oxygen per cubic meter, therefore the engine is getting more oxygen for any given speed. Same principle as what your intercooler is trying to do. Cheer Andy |
5th Jan 2017 7:52pm |
so will a more capable intercooler make the engine run better and more consistent?
6th Jan 2017 7:59am |
Absolutely, but there is a trade off between air cooling and creating a restriction on the air flow which effectively starves the engine of air.
So what I'm trying to say is an intercooler is a carefully designed component to maximise air flow for a given temp drop. Check out the BAS airflow, there is quite a bit of info out there on that. Cheers. Andy. |
6th Jan 2017 8:08am |
might sell it a buy a td5?
11th Jan 2017 1:25pm |
Dreamweapon Member Since: 19 Dec 2016 Location: Hessische Odenwald Posts: 55 |
Try changing onto an "Ultimate" or "Premium" diesel for a couple of tanks, or adding a good quality diesel additive. Always helps mine when it gets too rattly.
13th Jan 2017 12:22pm |
I occasionally drive a luton van which is an 07 plate with a puma 2.4.
That makes the same detonation noise although its not as prominent due to having more sound insulation than my defender |
13th Jan 2017 12:42pm |
What do you class as a good quality diesel additive?
13th Jan 2017 12:43pm |
