![]() | Home > Puma (Tdci) > can sound like bag of spanners when cold accelerating |
Vmesch Member Since: 06 Dec 2014 Location: Antwerp - Lier Posts: 47 ![]() ![]() |
Has anyone noticed some kind of power increase when experiencing the 'bag of spanners' phenomenon? I was driving home last day and was cruising at constant speed when it occurred (cold motor) and it was speeding up without changing the position of my foot on the pedal.... This could be pointing towards air intake problem? puma 2.2 MY2013
[:O]===[O:] |
neverin Member Since: 26 Sep 2016 Location: worksop Posts: 47 ![]() ![]() ![]() |
ive often wondered about air temperature as the engine seems stronger the colder the weather?
just same thoughts from my side: the colder the weather, the smoother it runs!
![]() [:O]===[O:] |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 ![]() ![]() ![]() |
Colder air means it's more dense, packed with more oxygen per cubic meter, therefore the engine is getting more oxygen for any given speed. Same principle as what your intercooler is trying to do. Cheer Andy |
so will a more capable intercooler make the engine run better and more consistent?
Absolutely, but there is a trade off between air cooling and creating a restriction on the air flow which effectively starves the engine of air.
So what I'm trying to say is an intercooler is a carefully designed component to maximise air flow for a given temp drop. Check out the BAS airflow, there is quite a bit of info out there on that. Cheers. Andy. |
might sell it a buy a td5?
Dreamweapon Member Since: 19 Dec 2016 Location: Hessische Odenwald Posts: 55 ![]() ![]() ![]() |
Try changing onto an "Ultimate" or "Premium" diesel for a couple of tanks, or adding a good quality diesel additive. Always helps mine when it gets too rattly.
I occasionally drive a luton van which is an 07 plate with a puma 2.4.
That makes the same detonation noise although its not as prominent due to having more sound insulation than my defender |
What do you class as a good quality diesel additive?
