Home > Group Buys > Genuine Landrover TD5 Rev Counter
Sign Up
(9)
User Registered Confirmed
Green Machine4th Jan 2017 3:18pm
boode4th Jan 2017 3:30pm
pj21064th Jan 2017 4:47pm
Disco_Mikey4th Jan 2017 7:11pm
Paddie424th Jan 2017 8:16pm
farmer giles5th Jan 2017 10:11am
JimboSails28th Jan 2017 12:12pm
ppad17th Feb 2017 8:34pm
Baz804620th Feb 2017 11:10pm
Page 3 of 3 <123
Martin
Site Admin
boode wrote:
Hi Martin
I have just ordered a wire terminal and 3 Td5 switch connectors - the PayPal transaction went through but web site crashed - please confirm that the order has been placed
Something looks like it went wrong with PayPal but your order and payment have come through fine Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #590377 5th Jan 2017 1:30pm
AJC
Martin wrote:
If anyone fitting these needs a wire/terminal for the ECU plug I sell them on the site shop:
http://www.defender2.net/shop/td5-ecu-pin-...r-p62.html
Hi Martin, that's spot on, but correct me if I'm wrong, but 30cm of wire supplied isn't enough to go to the back of the rev counter from the ecu? Cheers
Post #590393 5th Jan 2017 2:32pm
Martin
Site Admin
Correct - it's not a full fitting kit (you would also need power and illumination and ground for the rev counter).
It's simply to give a connection to the rev counter signal on the ECU plug.
I could put together a full retrofit wiring kit but it would be more than £1.60 Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #590396 5th Jan 2017 2:53pm
AJC
Got ya,
As much as I like the thought of a rev counter, I can't help but think I don't need one. I must walk away from computer now or I will end up buying one
Post #590397 5th Jan 2017 2:56pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Just caught up with this. I'll give Dan a call on Monday Bow down
Post #591013 7th Jan 2017 4:39pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Hi Martin, do you know if its possible to take the power, illumination and ground from the clock assuming I don't plan on reusing it?
Post #592104 11th Jan 2017 12:24pm
farmer giles
rev counter received - many thanks Dan Thumbs Up and pj for organising Thumbs Up
I have seen full wiring kits for td5 rev counters from Croytec for £20 if that helps anyone?
cheers
Post #592461 12th Jan 2017 2:33pm
Martin
Site Admin
You can take ground and illumination from the clock. The power for the clock is permanent so you need to borrow an ignition switched source from another gauge.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #592471 12th Jan 2017 2:46pm
Martin
Site Admin
Croytec's "loom" appears to be 5 spade connectors on a short piece of wire each. Not a plug-and-play loom?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #592474 12th Jan 2017 2:49pm
Green Machine
Is there a 'rule of thumb' as to which vehicles will have the rev counter wiring in place behind the instrument panel and which will not? 2005 Td5 | 90 Station Wagon | Tonga Green
Post #594132 18th Jan 2017 4:13pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Check pin 19 on your black ecu plug if has a grey wire then 👍 Just gotta find it behind the clocks 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #594199 18th Jan 2017 7:28pm
Martin
Site Admin
Pin 19 is connected for vehicles with ABS so not always an indication it will be behind the clocks.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #594258 18th Jan 2017 9:54pm
ppad
United Kingdom 2005 Defender 90 Td5 HT Caledonian Blue
Well it's ticked over the end date of 31 Jan , but within a Land Rover margin of timing Whistle
(Good excuse, was in Grampians, VIC)
I'm in if this is still happening. Sold the much modified 110 2.8, in Oz
Brought the 90 home from Switzerland ...
Post #602706 17th Feb 2017 8:42pm
pj2106
Read earlier in the post as Dan has posted details for purchase 👍 2008 110 2.4 XS Utility (Hagrid)
Post #602715 17th Feb 2017 9:14pm
Baz8046
United Kingdom 2002 Defender 90 Td5 HT Rutland Red
Bit late to this one but hopefully it is still open.
Any problems Dan just let me know. Defender Td5 Commercial 2002
Range Rover L322 TDV8 Westminster 2012
Discovery 4 SDV6 Landmark 2016
Post #603466 20th Feb 2017 11:12pm
Page 3 of 3 <123
